i have recently set up a new instance of homematic os on my proxmox server together with a raspberrymatic ccu on a Raspberry Pi 2 with a HM-MOD-RPI-PCB. So far i was successfully able to pair all my heating thermostats with the ccu and pass those to my homeassistant. I have also created some widgets for the thermostats on a dashboard.
Now, when i try to set anything on the dashboard using the widget, it does not change the widget state. Allthough i have noticed within the ccu web-frontend, that my “commands” are passed through and set on the thermostat accordingly.
Example: I click on the heat
button (with the flame icon). The widget still indicates, that the thermostat is set to automatic
. But in the ccu and on the thermostat, i can see, that the mode is changed to manual
, which is correct.
I have integrated the homematic ccu via YAML, like it is described in the examples. Here is the yaml-snipped from my configuration.yaml
homematic:
interfaces:
rf:
host: 192.168.0.111
resolvenames: xml
port: 2001
username: "ha-user"
password: "redacted"
hosts:
ccu2:
host: 192.168.0.111
port: 2001
username: "ha-user"
Here are some infos from the haos
haos: 9.5
homeassistant: 2023.6.3
supervisor: 2023.4.0
My CCU infos
firmwareversion: 3.67.10.20230225
NEO SERVER: 2.12.1
XML-API: 1.22
