Thanks @m0wlhed for the proposal.
I do not feel for the moment to have the knowledge actually to setup this configuration , so I will use the method i have seen in the forum :
=> nfs-common has been installed in the Debian OS for the connection issue = OK
1) manual mount command from the homeassistant container in the Portainer console
mount -t nfs 192.168.1.xx:/volum1/homes/xxxxx/ /config/media/xxxx/
2) test with “developper Tools/Service”
service : camera.screenshot
entity : Test camera
service data :
entity_id: camera.xxxx_ovprofile00
filename: /config/media/camera/test.jpg
=> The test.jpg camera screenshot is sent to the proper NAS folder (volume1/homes/xxxx) = OK
3) Test with an automation ( camera screeshot sent to NAS when motion detected)
Automation code
- id: '1599228545663'
alias: Motion FGMS-01
description: Actions suite motion Fibaro FGMS-01
- device_id: c52b50d6959a439a8ce79b8cae0db055
domain: binary_sensor
entity_id: binary_sensor.fgms001_zw5_motion_sensor_home_security_motion_detected
platform: device
type: motion
condition:
- condition: or
conditions:
- condition: state
entity_id: alarm_control_panel.home_alarm
state: armed_away
- condition: state
state: armed_night
- data:
message: AUTOMATION! Motion sensor FGMS-01 triggered in Away / Night mode
service: notify.pushbullet
- data:
entity_id: camera.dcs_942l_ovprofile00
filename: /config/media/camera/D942L_{{ now().strftime("%Y%m%d-%H%M%S") }}.jpg
service: camera.snapshot
mode: single
=> There is a camera screenshot ( jpg file ) in the NAS shared folder = OK but not in the HA local folder (NOK)
4) Automatic mapping of the NFS folder mount
To create an automation each time you reboot the docker or the HA , so the mapping will be restored
# Custom Shell
shell_command:
map_nas_camera_folder: mount -t nfs 192.168.1.xxx:/volume1/homes/xxxxx/ /config/media/xxxxx
- id: '1611660762952'
alias: NAS folder mounting
description: ''
- platform: homeassistant
event: start
condition: []
- service: shell_command.map_nas_camera_folder
data: {}
mode: single
4) Remaining issue
a) I can view the camera screenshot in the NAS web browser in the remote NAS share folder ( volume1/homes/xxxx) but not in HA local folder /config/media/xxxx as I expect .
Is it a normal behavior ?
I noticed that accessing the local folder using SSH is OK ( jpg files are there) but not from the Web Browser ( folder empty)
b) I agree that this NFS setup is a workaround solution
