Solved. Wyoming satellite (Pi zero 2W + 2mic board) - failed install, deleted - and now not discovered?
I’ve just built a third wyoming satellite module with a pi zero 2w & two mic board.
The first two were recognised & work fine.
When this third one was first recognised (under settings > devices > Wyoming protocol), it did not set up correctly.
I deleted the errored device & restarted everything, expecting it to be detected again - but its not? No sign of the third device despite it being on line to an ssh connection and all the services showing as running correctly?
How and where do I delete the relevant data so it’s detected again as a new device?
Or, do I Delete Wyoming completely - but can I do that without messing up piper & whisper etc??
Thanks, Robert.
Fixed.
I never managed to find the problem with that new build, it was absolutely identical to the previous ones as far as I could tell, but rebuilt as the new SD cards were smaller so I could not simply clone an existing one, as I did for the second build.
I found a tool to clone to a smaller card directly on the Pi zero:
A clone of a working one, with the hostname, satellite device name and IP address, made on one of the new small cards, then works perferctly.
I’m running into this issue that my Wyoming Satellite isn’t being discovered anymore. It’s running just fine. I don’t have another sd card with a working copy. This seems to be a larger issue in HA. It’s like HA is holding onto the previous Wyoming Satellite data even though I’ve deleted the integration and restarted HA a million times.
