SOLVED: Yellow, reinstallation fails after updates kept failing
Dear Community,
My Yellow with 500GB Kingston NV2 NVMe did not update anymore for some months or so. (i do not have the exact logs and versions, it spontaneously stopped updating).
Now I have done several attempts to reset and reinstall.
After the red + blue button with usb-stick method, i now tried also via usb-recovery for the second time.
This seems to work at first, Home Assistant observer all green.
But poort 8123 keeps giving me an " Error installing Home Assistant"
Here I put the log.
https://www.dropbox.com/scl/fo/wzgdx5zsb4x9ufvmq6bjz/AJLWu-aEx__Wh92a_JYz9VQ?rlkey=z064r70x8fwhddk0qtddjwnmw&st=9q4c76x3&dl=0
Any suggestion what this could be and how to solve ?
Martin.
Hope this is helpful for the others.
I removed the NVMe at the end and did a reinstall with USB cable, rpiboot and rpiā€“imager.
Now after reboot the setup came up and I could reinstall everything.
Not sure I should put back the backup, it might be corrupt so i will not do this.
As i will move house this year this is ok.
New house with all kind of nice zigbee dimmers and stuff :slight_smile:
Martin.
