Hi everybody,
A couple of hours since I’m stuck in setting z-wave. I’ve read more then once the documentation and several topics here, but without any success. So, my turn to ask for your help.
I’ve received today my Sigma Designs Z-Wave Plus dongle, with some Eurotronic Spirit Z-Wave+ TRV. I’ve plugged the USB on my RPI3 (running Hass.IO), update the configuration.yaml and restart HA : OpenZWave start the network and … nothing. Like OZW is continuously starting the network.
(Sorry - still in French)
For information, initially I was running HA 0.103.x. After few hours I’ve upgrade to 0.104.3 to check if that could make any difference (spoiler alert : no).
I’ve also try the 3 differents “address” for the usb in the configuration.yaml :
/dev/ttyACM0
/dev/ttyAMA0
/dev/serial/by-id/usb-0658_0200_32303136-3131-3033-3030-303032343933-if00
But I still have the same log into OZW :
2020-01-23 22:37:10.131 Always, OpenZwave Version 1.4.3452 Starting Up
2020-01-23 22:37:43.250 Info, Setting Up Provided Network Key for Secure Communications
2020-01-23 22:37:43.250 Warning, Failed - Network Key Not Set
2020-01-23 22:37:43.250 Info, mgr, Added driver for controller /dev/serial/by-id/usb-0658_0200_32303136-3131-3033-3030-303032343933-if00
2020-01-23 22:37:43.250 Info, Opening controller /dev/serial/by-id/usb-0658_0200_32303136-3131-3033-3030-303032343933-if00
2020-01-23 22:37:43.250 Info, Trying to open serial port /dev/serial/by-id/usb-0658_0200_32303136-3131-3033-3030-303032343933-if00 (attempt 1)
2020-01-23 22:37:43.251 Info, Serial port /dev/serial/by-id/usb-0658_0200_32303136-3131-3033-3030-303032343933-if00 opened (attempt 1)
2020-01-23 22:37:43.252 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-01-23 22:37:43.252 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-01-23 22:37:43.252 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-01-23 22:37:43.252 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-01-23 22:37:43.252 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-01-23 22:37:43.252 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-01-23 22:37:43.255 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x36, 0x2e, 0x30, 0x31, 0x00, 0x01, 0x91
2020-01-23 22:37:43.255 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2020-01-23 22:37:43.255 Info, contrlr, Static Controller library, version Z-Wave 6.01
2020-01-23 22:37:43.255 Detail, Node045, Expected reply was received
2020-01-23 22:37:43.255 Detail, Node045, Message transaction complete
2020-01-23 22:37:43.255 Detail, contrlr, Removing current message
2020-01-23 22:37:43.255 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-01-23 22:37:43.258 Detail, contrlr, Received: 0x01, 0x08, 0x01, 0x20, 0xff, 0xff, 0xff, 0xfe, 0xef, 0x38
2020-01-23 22:37:43.259 Detail,
2020-01-23 22:37:43.259 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xfffffffe. Our node ID = 239
2020-01-23 22:37:43.259 Detail, contrlr, Expected reply was received
2020-01-23 22:37:43.259 Detail, contrlr, Message transaction complete
2020-01-23 22:37:43.259 Detail, contrlr, Removing current message
2020-01-23 22:37:43.259 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-01-23 22:37:43.261 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x28, 0xd7
2020-01-23 22:37:43.261 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2020-01-23 22:37:43.261 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2020-01-23 22:37:43.261 Info, contrlr, The PC controller is a primary controller.
2020-01-23 22:37:43.261 Detail, Node215, Expected reply was received
2020-01-23 22:37:43.261 Detail, Node215, Message transaction complete
2020-01-23 22:37:43.261 Detail, contrlr, Removing current message
2020-01-23 22:37:43.261 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-01-23 22:37:43.265 Detail, contrlr, Received: 0x01, 0x2b, 0x01, 0x07, 0x05, 0x0e, 0x00, 0x00, 0x00, 0x03, 0x00, 0x08, 0xfe, 0x87, 0x7f, 0x88, 0xcf, 0x7f, 0xc0, 0x4f, 0xfb, 0xdf, 0xfd, 0xe0, 0x67, 0x00, 0x80, 0x80, 0x00, 0x80, 0x86, 0x00, 0x01, 0x00, 0xe8, 0x73, 0x00, 0x80, 0x0f, 0x00, 0x00, 0x60, 0x00, 0x00, 0x4e
2020-01-23 22:37:43.266 Detail,
2020-01-23 22:37:43.266 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2020-01-23 22:37:43.266 Info, contrlr, Serial API Version: 5.14
2020-01-23 22:37:43.266 Info, contrlr, Manufacturer ID: 0x0000
2020-01-23 22:37:43.266 Info, contrlr, Product Type: 0x0003
2020-01-23 22:37:43.266 Info, contrlr, Product ID: 0x0008
2020-01-23 22:37:43.266 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-01-23 22:37:43.266 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-01-23 22:37:43.266 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-01-23 22:37:43.266 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2020-01-23 22:37:43.266 Detail, Node014, Expected reply was received
2020-01-23 22:37:43.266 Detail, Node014, Message transaction complete
2020-01-23 22:37:43.266 Detail, contrlr, Removing current message
2020-01-23 22:37:43.266 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-01-23 22:37:43.268 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2020-01-23 22:37:43.268 Info, contrlr, Received reply to GET_SUC_NODE_ID. Node ID = 0
2020-01-23 22:37:43.268 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2020-01-23 22:37:43.268 Detail, Node172, Expected reply was received
2020-01-23 22:37:43.268 Detail, Node172, Message transaction complete
2020-01-23 22:37:43.268 Detail, contrlr, Removing current message
2020-01-23 22:37:43.269 Detail,
2020-01-23 22:37:43.269 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-01-23 22:37:43.326 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0xd8, 0xfb, 0xd1, 0xb2, 0x14, 0xac, 0x93, 0x26, 0x95, 0x1b, 0x28, 0x3c, 0x31, 0x79, 0xd6, 0xf7, 0x59, 0x99, 0xc9, 0x65, 0x18, 0x30, 0xf0, 0x7a, 0x32, 0xc8, 0xf2, 0x52, 0x09, 0xfa, 0xc9, 0x14, 0xe2
2020-01-23 22:37:43.326 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2020-01-23 22:37:43.326 Detail, Node032, Expected reply was received
2020-01-23 22:37:43.326 Detail, Node032, Message transaction complete
2020-01-23 22:37:43.326 Detail, contrlr, Removing current message
2020-01-23 22:37:43.327 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-01-23 22:37:43.424 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x02, 0x08, 0x00, 0x1d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xc9
2020-01-23 22:37:43.424 Info, mgr, Driver with Home ID of 0xfffffffe is now ready.
2020-01-23 22:37:43.424 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2020-01-23 22:37:43.424 Detail, Expected reply was received
2020-01-23 22:37:43.424 Detail, Message transaction complete
2020-01-23 22:37:43.424 Detail, contrlr, Removing current message
2020-01-23 22:37:43.424 Detail, Node239, Notification: DriverReady
2020-01-23 22:37:43.427 Detail,
2020-01-23 22:37:43.428 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-01-23 22:37:43.432 Detail, contrlr, Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2020-01-23 22:37:43.434 Detail,
2020-01-23 22:37:43.434 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2020-01-23 22:37:43.434 Detail, Node015, Expected reply was received
2020-01-23 22:37:43.434 Detail, Node015, Message transaction complete
2020-01-23 22:37:43.434 Detail, contrlr, Removing current message
2020-01-23 22:37:43.435 Detail,
2020-01-23 22:37:43.435 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2020-01-23 22:37:43.438 Detail, contrlr, Removing current message
If you have any idea on how to resolve this problem, I’m ready to hear it
