I had a perfectly good setup using ZHA with Sonoff 3.0 USB Dongle V2 E (using original firmware, no flashing) controlling multiple Zigbee devices.
For “reasons” I installed Mosquitto broker and Zigbee2MQTT on the side to run some tests. Afterwards I uninstalled both of them.
Now I can’t get ZHA to work anymore and I have no clue what’s wrong. My switches are greyed out but the ZHA “device” does seem connected to the USB dongle.
I tried:
ZHA backup (“migrate radio”)
Full restore of home assistant using an earlier full backup
Reconfiguring the zigbee devices, but this results in error
What could be going wrong?
When searching the home-assistant.log for zigbee, sonoff or zha this is the only thing I find:
2023-07-29 13:56:07.230 WARNING (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0x72DE:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>')]
ZHA diagnostics:
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.5.4",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.11",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Amsterdam",
"os_name": "Linux",
"os_version": "6.1.29",
"supervisor": "2023.07.1",
"host_os": "Home Assistant OS 10.2",
"docker_version": "23.0.6",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"smartthinq_sensors": {
"version": "0.31.8",
"requirements": [
"pycountry>=20.7.3",
"xmltodict>=0.12.0",
"charset_normalizer>=2.0.0"
"hacs": {
"version": "1.32.1",
"requirements": [
"aiogithubapi>=22.10.1"
"tapo": {
"version": "1.7.1",
"requirements": [
"plugp100==2.5.1"
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"after_dependencies": [
"onboarding",
"usb"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"config_flow": true,
"dependencies": [
"file_upload"
"documentation": "https://www.home-assistant.io/integrations/zha",
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"requirements": [
"bellows==0.35.5",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.99",
"zigpy-deconz==0.21.0",
"zigpy==0.55.0",
"zigpy-xbee==0.18.0",
"zigpy-zigate==0.11.0",
"zigpy-znp==0.11.1"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"type": "_slzb-06._tcp.local.",
"name": "slzb-06*"
"is_built_in": true
"data": {
"config": {},
"config_entry": {
"entry_id": "8e1c3e901e433952b93b29686004f3dd",
"version": 3,
"domain": "zha",
"title": "SONOFF Zigbee 3.0 USB Dongle Plus V2",
"data": {
"device": {
"path": "/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230329140052-if00",
"baudrate": 115200,
"flow_control": "software"
"radio_type": "ezsp"
"options": {},
"pref_disable_new_entities": false,
"pref_disable_polling": false,
"source": "usb",
"unique_id": "**REDACTED**",
"disabled_by": null
"application_state": {
"node_info": {
"nwk": 0,
"ieee": "**REDACTED**",
"logical_type": 0
"network_info": {
"extended_pan_id": "**REDACTED**",
"pan_id": 7972,
"nwk_update_id": 0,
"nwk_manager_id": 0,
"channel": 11,
"channel_mask": 134215680,
"security_level": 5,
"network_key": "**REDACTED**",
"tc_link_key": {
"key": [
90,
105,
103,
66,
101,
101,
65,
108,
108,
105,
97,
110,
99,
101,
48,
57
"tx_counter": 16384,
"rx_counter": 0,
"seq": 0,
"partner_ieee": "**REDACTED**"
"key_table": [],
"children": [],
"nwk_addresses": {},
"stack_specific": {
"ezsp": {
"hashed_tclk": "df19cb71ad1d9ddfe666315183598586"
"metadata": {
"ezsp": {
"manufacturer": "",
"board": "",
"version": "6.10.3.0 build 297",
"stack_version": 8,
"can_write_custom_eui64": true
"source": "[email protected]"
"counters": {
"controller_app_counters": {
"unicast_rx": {
"__type": "<class 'zigpy.state.Counter'>",
"repr": "Counter(name='unicast_rx', _raw_value=17, reset_count=0, _last_reset_value=0)"
"unicast_tx_success": {
"repr": "Counter(name='unicast_tx_success', _raw_value=24, reset_count=0, _last_reset_value=0)"
"broadcast_tx_success_unexpected": {
"repr": "Counter(name='broadcast_tx_success_unexpected', _raw_value=2, reset_count=0, _last_reset_value=0)"
"unicast_tx_failure": {
"repr": "Counter(name='unicast_tx_failure', _raw_value=17, reset_count=0, _last_reset_value=0)"
"broadcast_rx": {
"repr": "Counter(name='broadcast_rx', _raw_value=1, reset_count=0, _last_reset_value=0)"
"ezsp_counters": {
"MAC_RX_BROADCAST": {
"repr": "Counter(name='MAC_RX_BROADCAST', _raw_value=90, reset_count=0, _last_reset_value=0)"
"MAC_TX_BROADCAST": {
"repr": "Counter(name='MAC_TX_BROADCAST', _raw_value=111, reset_count=0, _last_reset_value=0)"
"MAC_RX_UNICAST": {
"repr": "Counter(name='MAC_RX_UNICAST', _raw_value=20, reset_count=0, _last_reset_value=0)"
"MAC_TX_UNICAST_SUCCESS": {
"repr": "Counter(name='MAC_TX_UNICAST_SUCCESS', _raw_value=57, reset_count=0, _last_reset_value=0)"
"MAC_TX_UNICAST_RETRY": {
"repr": "Counter(name='MAC_TX_UNICAST_RETRY', _raw_value=16, reset_count=0, _last_reset_value=0)"
"MAC_TX_UNICAST_FAILED": {
"repr": "Counter(name='MAC_TX_UNICAST_FAILED', _raw_value=5, reset_count=0, _last_reset_value=0)"
"APS_DATA_RX_BROADCAST": {
"repr": "Counter(name='APS_DATA_RX_BROADCAST', _raw_value=2, reset_count=0, _last_reset_value=0)"
"APS_DATA_TX_BROADCAST": {
"repr": "Counter(name='APS_DATA_TX_BROADCAST', _raw_value=2, reset_count=0, _last_reset_value=0)"
"APS_DATA_RX_UNICAST": {
"repr": "Counter(name='APS_DATA_RX_UNICAST', _raw_value=17, reset_count=0, _last_reset_value=0)"
"APS_DATA_TX_UNICAST_SUCCESS": {
"repr": "Counter(name='APS_DATA_TX_UNICAST_SUCCESS', _raw_value=24, reset_count=0, _last_reset_value=0)"
"APS_DATA_TX_UNICAST_RETRY": {
"repr": "Counter(name='APS_DATA_TX_UNICAST_RETRY', _raw_value=23, reset_count=0, _last_reset_value=0)"
"APS_DATA_TX_UNICAST_FAILED": {
"repr": "Counter(name='APS_DATA_TX_UNICAST_FAILED', _raw_value=17, reset_count=0, _last_reset_value=0)"
"ROUTE_DISCOVERY_INITIATED": {
"repr": "Counter(name='ROUTE_DISCOVERY_INITIATED', _raw_value=11, reset_count=0, _last_reset_value=0)"
"NEIGHBOR_ADDED": {
"repr": "Counter(name='NEIGHBOR_ADDED', _raw_value=1, reset_count=0, _last_reset_value=0)"
"NEIGHBOR_REMOVED": {
"repr": "Counter(name='NEIGHBOR_REMOVED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"NEIGHBOR_STALE": {
"repr": "Counter(name='NEIGHBOR_STALE', _raw_value=1, reset_count=0, _last_reset_value=0)"
"JOIN_INDICATION": {
"repr": "Counter(name='JOIN_INDICATION', _raw_value=0, reset_count=0, _last_reset_value=0)"
"CHILD_REMOVED": {
"repr": "Counter(name='CHILD_REMOVED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"ASH_OVERFLOW_ERROR": {
"repr": "Counter(name='ASH_OVERFLOW_ERROR', _raw_value=0, reset_count=0, _last_reset_value=0)"
"ASH_FRAMING_ERROR": {
"repr": "Counter(name='ASH_FRAMING_ERROR', _raw_value=0, reset_count=0, _last_reset_value=0)"
"ASH_OVERRUN_ERROR": {
"repr": "Counter(name='ASH_OVERRUN_ERROR', _raw_value=0, reset_count=0, _last_reset_value=0)"
"NWK_FRAME_COUNTER_FAILURE": {
"repr": "Counter(name='NWK_FRAME_COUNTER_FAILURE', _raw_value=0, reset_count=0, _last_reset_value=0)"
"APS_FRAME_COUNTER_FAILURE": {
"repr": "Counter(name='APS_FRAME_COUNTER_FAILURE', _raw_value=0, reset_count=0, _last_reset_value=0)"
"UTILITY": {
"repr": "Counter(name='UTILITY', _raw_value=0, reset_count=0, _last_reset_value=0)"
"APS_LINK_KEY_NOT_AUTHORIZED": {
"repr": "Counter(name='APS_LINK_KEY_NOT_AUTHORIZED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"NWK_DECRYPTION_FAILURE": {
"repr": "Counter(name='NWK_DECRYPTION_FAILURE', _raw_value=0, reset_count=0, _last_reset_value=0)"
"APS_DECRYPTION_FAILURE": {
"repr": "Counter(name='APS_DECRYPTION_FAILURE', _raw_value=0, reset_count=0, _last_reset_value=0)"
"ALLOCATE_PACKET_BUFFER_FAILURE": {
"repr": "Counter(name='ALLOCATE_PACKET_BUFFER_FAILURE', _raw_value=0, reset_count=0, _last_reset_value=0)"
"RELAYED_UNICAST": {
"repr": "Counter(name='RELAYED_UNICAST', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PHY_TO_MAC_QUEUE_LIMIT_REACHED": {
"repr": "Counter(name='PHY_TO_MAC_QUEUE_LIMIT_REACHED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PACKET_VALIDATE_LIBRARY_DROPPED_COUNT": {
"repr": "Counter(name='PACKET_VALIDATE_LIBRARY_DROPPED_COUNT', _raw_value=0, reset_count=0, _last_reset_value=0)"
"TYPE_NWK_RETRY_OVERFLOW": {
"repr": "Counter(name='TYPE_NWK_RETRY_OVERFLOW', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PHY_CCA_FAIL_COUNT": {
"repr": "Counter(name='PHY_CCA_FAIL_COUNT', _raw_value=0, reset_count=0, _last_reset_value=0)"
"BROADCAST_TABLE_FULL": {
"repr": "Counter(name='BROADCAST_TABLE_FULL', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PTA_LO_PRI_REQUESTED": {
"repr": "Counter(name='PTA_LO_PRI_REQUESTED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PTA_HI_PRI_REQUESTED": {
"repr": "Counter(name='PTA_HI_PRI_REQUESTED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PTA_LO_PRI_DENIED": {
"repr": "Counter(name='PTA_LO_PRI_DENIED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PTA_HI_PRI_DENIED": {
"repr": "Counter(name='PTA_HI_PRI_DENIED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PTA_LO_PRI_TX_ABORTED": {
"repr": "Counter(name='PTA_LO_PRI_TX_ABORTED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"PTA_HI_PRI_TX_ABORTED": {
"repr": "Counter(name='PTA_HI_PRI_TX_ABORTED', _raw_value=0, reset_count=0, _last_reset_value=0)"
"ADDRESS_CONFLICT_SENT": {
"repr": "Counter(name='ADDRESS_CONFLICT_SENT', _raw_value=0, reset_count=0, _last_reset_value=0)"
"EZSP_FREE_BUFFERS": {
"repr": "Counter(name='EZSP_FREE_BUFFERS', _raw_value=249, reset_count=0, _last_reset_value=0)"
"broadcast_counters": {},
"device_counters": {},
"group_counters": {}
"energy_scan": {
"11": 13.711043742539033,
"12": 8.631361812931262,
"13": 52.75969252664325,
"14": 49.512515447068886,
"15": 46.26944564832987,
"16": 80.38447947821754,
"17": 96.64469941013013,
"18": 95.69133648577223,
"19": 78.25348754651363,
"20": 59.15797905332195,
"21": 55.9836862725909,
"22": 10.914542804728702,
"23": 23.33483723001185,
"24": 36.830390267097734,
"25": 23.33483723001185,
"26": 75.96022321405563
"versions": {
"bellows": "0.35.5",
"zigpy": "0.55.0",
"zigpy_deconz": "0.21.0",
"zigpy_xbee": "0.18.0",
"zigpy_znp": "0.11.1",
"zigpy_zigate": "0.11.0",
"zhaquirks": "0.0.99"
