Hi Guys,
A fairly newbie here, so apologizing in advance
I just got my hands on a light switch that is zigbee compatible.
ZigBee Wall Touch Smart Light Switch With Neutral/No Neutral,No Capacitor Smart Life/Tuya 2/3 Way Control compatible AlexaGoogle
And my Home Assistant Zigbee finds it, and it works fine (kind of).
Problem is that this light switch has two gangs (switches), and when I click them individually on the switch it self it works great, the one I click activates and only this one.
If I click on the button in Home Assistant, both switches activates!
I have up to date versions (I think)
Home Assistant 2023.9.0
Supervisor 2023.08.3
Operating System 10.5
Frontend 20230906.1 - latest
The fingerprint is as follows
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": "0x0104",
"device_type": "0x0100",
"input_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006"
"output_clusters": [
"0x0019"
"2": {
"input_clusters": [
"0x0004",
"0x0005",
"0x0006"
"output_clusters": []
"manufacturer": "_TZ3000_18ejxno0",
"model": "TS0012",
"class": "zhaquirks.tuya.ts001x.TuyaDoubleNoNeutralSwitch_2"
Thanks for any suggestion on how to fix this in advance
Cheerts
Bengt
