[SOLVED] Zigbee2mqtt not up to date
zigbee2mqtt add-on version in HA is “Current version: 1.18.1-1”
no update is available
Latest version on github is “v1.22.1-1”
Is it normal?
Change repositories. You are still using the deprecated Daniel Welch repository. Uninstall it and install the official repository.
That worked. Thank you!
The link to the repository, if it can help others: GitHub - zigbee2mqtt/hassio-zigbee2mqtt: Zigbee2mqtt Home Assistant add-on
I’am having the same issue here.
When i updated as described above, will i lose all my settings from zigbee2mqtt?
