Solving Error / Removing Error
I’m trying to remove this helper but it has an error everytime I click it.
Config flow could not be loaded: {“message”:“Invalid handler specified”}
The underlying entity is from the Kasa integration and I think it was replaced. Do you know how I can remove this manually?
I’ve also remove all the reference to what I believe would be that “switch_ax_x” in the “core.entity_registry” and restarted and it’s still there. Do you have any ideas?
So after restarting, the entry in “core.entity_registry” get’s added back. Why would that be?
