Since supervised installation is finally not abandoned, I decided to give a try on my odroid N2 with Coreelec.
I’ve managed to get Home Assistant and the supervisor installation on Correelec (should work also with Libreelec) with some modification ($path an library path) of the installer. Everything’s is working great (discover, updates…).
The problem is some addons cannot launch for an unknow reason and others work with no problems!
For exemple: File editor works perfectly. Mosquitto broker zigbee2mqtt doesn’t start and only give me the following log ->
Any ideas? Thanks in advance.
If it finally works, I will gitclone https://github.com/home-assistant/supervised-installer
and share my modifications for Coreelec/Librreelec (I know there is peoples interested as I’ve seen many post on this). Thanks in advance (again!).
