Hi. I’m completely new to all of this.
So far, I have Home Assistant running on my Raspberry Pi and all seems good.
This morning I finally connected the Pi up to a screen and it’s asking for my HassIO login.
Should this be the same as my HassIO login in the Configuration? If so it’s not letting me in. I’m logged into HassIO via Chrome on my Mac though.
After the login times out I’m getting:
Welcome to HassOS
Hassio login: [bunch of numbers] IPV6: ADDRCONF(NETDEV_UP): wlan0: link not ready
[bunch of numbers] brcmfmac: power management disabled
I’m trying to get to the yaml file so I can get started but am now totally stuck.
Has HassOS replaced Raspian on my Pi? I’m fine with that but, as I said, very new to all things Pi, HassIO and HassOS.
Hi
Hassio on the Pi uses headless mode so if you plug a hdmi lead into the pi it will only show the home assistant logo and it is not a control method. It seem your doing right by logging in via a web browser on another device. Hope i understand what you are asking? good luck on your journey, i can be hard to get stared but boy it’s great when you set it all up.
Ok can you see HA overview when you log in via your web browser?
If you can you should see a list on the right hand side you should see a tab called Hass.io?
If you can see this click on it and go to addon store download configurator to access the configuration files via web browser & or samba to access them via your home home/work network.
If I follow you, you would edit your yaml on your Mac as I don’t know which route you used to install on your pi. I never touch my pi I do everything from my pc or tablet via a web browser.
That is fine for now, you may want to make it more secure later. Personally I would use the configuator to start with as writing yaml is a bit challenging as correct spacing is vital to make it work & it will tell you if your code is formatted correctly.
