hello I am using Ns panel in Home Assistant as it is working very fine so I have designed 3 pages HMI in nextion and upload the TFT file in home assistant it is uploaded very well and working very fine now when I have to access the page 1 and page 2 stuff like some sensors are on page 2 and page 3 so it did not give me any response and everything is on page 0 is working very well in home assistant except page 2 and page 3 I don’t know why? anything in the coding maybe I am uploading
the coding picture so can check and give me some direction thank you.
All this is one sentence.
That is not readable.
I don’t understand what is working and what is not working.
Also, how many pages was it?
3? 1, 2 and 3?
What is page 0 then?
And lastly upload code as text, images are hard to read and we can’t edit them to fix things.
Actually I’ve main pages 0, 1, 2
Set some variables for convenience
substitutions:
node_name: shawn-touchscreeen
device_name: permia
Note: this may not be needed if the pull request has been merged.
Check https://github.com/esphome/esphome/pull/2956 for current status.
external_components:
- source: github://pr#2956
components: [nextion]
refresh: 1h
esphome:
comment: $device_name
esp32:
board: esp32dev
Enable logging
logger:
Enable wireless updates
ota:
Enable Home Assistant API
api:
services:
# Service to play a song
- service: play_rtttl
variables:
song_str: string
then:
- rtttl.play:
rtttl: !lambda ‘return song_str;’
- service: upload_tft
then:
- lambda: ‘id(disp1)->upload_tft();’
A reboot button is always useful
button:
- platform: restart
name: Restart $device_name
Define some inputs
binary_sensor:
platform: gpio
name: $device_name Left Button
pin:
number: 14
inverted: true
on_click:- switch.toggle: relay_1
platform: gpio
name: $device_name Right Button
pin:
number: 27
inverted: true
on_click:- switch.toggle: relay_2
platform: nextion
name: $device_name Touch me
page_id: 0
component_id: 0 -
platform: nextion
page_id: 1
component_id: 1
platform: wifi_signal
name: $device_name WiFi Signal
update_interval: 60s -
platform: ntc
sensor: resistance_sensor
calibration:
b_constant: 3950
reference_temperature: 25°C
reference_resistance: 10kOhm
name: $device_name Temperature -
platform: resistance
sensor: ntc_source
configuration: DOWNSTREAM
resistor: 11.2kOhm -
platform: adc
pin: 38
update_interval: 10s
attenuation: 11db
Grab current temperature from Home Assistant
- platform: homeassistant
entity_id: weather.home
attribute: temperature
on_value:Push it to the display
then:
- lambda: ‘id(disp1).set_component_text_printf(“temp”, "%.1f “”\xb0"“F”, x);’
Define some outputs
switch:
The two relays
- platform: gpio
name: $device_name Relay 1
pin:
number: 22 - platform: gpio
name: $device_name Relay 2
pin:
number: 19
Pin 4 always needs to be on to power up the display
- platform: gpio
entity_category: config
pin:
number: 4
inverted: true
restore_mode: ALWAYS_ON
number:
platform: template
name: $device_name Brightness
unit_of_measurement: ‘%’
min_value: 0
max_value: 100
step: 1
initial_value: 30
set_action:
then:
- lambda: ‘id(disp1).set_backlight_brightness(x/100);’
Configure the internal bleeper
output:
- platform: ledc
pin:
number: 21
Enable ringtone music support
rtttl:
output: buzzer_out
Configure UART for communicating with the screen
uart:
tx_pin: 16
rx_pin: 17
baud_rate: 115200
Configure the screen itself
display:
- platform: nextion
uart_id: tf_uart
tft_url: http://192.168.0.124:8123/local/muhammad.tftA little fun…
on_setup:
then:
- number.set:
value: 30
- lambda: |-
“temp”, "%.1f “”\xb0"“F”, id(current_temperature).state
- rtttl.play: “twobits:d=4,o=5,b=220:c6,8g,8g,a,g,p,b,c6”
