I had a Dusun Gateway installed with HA system and run some tests about the ZHA integration. Got the following five issues,
- ZHA integration fails after device restart, got several times with one hundred time tries
- After removing the ZigBee device, paired the devices again. The first attempt fails, but the second one succeeds
- After the ZigBee device is removed and the gateway is restarted, the device information remains
- Sometimes failed to remove the ZigBee device. I need to restart the device to remove the ZigBee device
- If the network is configured for 50 times, sub-device information is incomplete
Test with Homeassistant blue board using ODROID N2+ as well and got the same result.
Would be appreciate with any assistance.
