I’ve tried a lot of things, but all of the “daily energy” entities are missing for me.
I have about 247 entities for my 2 Deye 8K, but no one of them tells me :
-daily PV energy
-daily grid energy
-daily battery energy
-daily load energy
But they have to be there because I can see this data in the Solar Assistant.(runs on another Raspberry which i bought)
Does anyone know how to add the entities in HA via mqtt from Solar Assitant?
All energy entity data for me refers to “weeks”-added,
So on Monday everything is still good… On Tuesday all the energy data (battery charging, house consumption, solar yield, etc.) is added up… till Sunday … so this is clear …weekly statistics entities.
I searched everything, the values are not displayed in HA for “daily energy”?!
How do I teach him this by hand? Is it possible ?
This entities are what I get from the installation:
Deye/SunSynk/Sol-Ark 3 Phase x 2 Inverter 2 - Temperature
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_temperature
MQTT
Keller
Deye/SunSynk/Sol-Ark 3 Phase x 2 Inverter 2 - Use timer
switch.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_use_timer
MQTT
Keller
Deye/SunSynk/Sol-Ark 3 Phase x 2 Inverter 2 - Voltage point 1
number.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_voltage_point_1
MQTT
Keller
Deye/SunSynk/Sol-Ark 3 Phase x 2 Inverter 2 - Voltage point 2
number.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_voltage_point_2
MQTT
Keller
Deye/SunSynk/Sol-Ark 3 Phase x 2 Inverter 2 - Voltage point 3
number.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_voltage_point_3
MQTT
Keller
Deye/SunSynk/Sol-Ark 3 Phase x 2 Inverter 2 - Voltage point 4
number.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_voltage_point_4
MQTT
Keller
Deye/SunSynk/Sol-Ark 3 Phase x 2 Inverter 2 - Voltage point 5
number.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_voltage_point_5
MQTT
Keller
Deye/SunSynk/Sol-Ark 3 Phase x 2 Inverter 2 - Voltage point 6
number.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_voltage_point_6
MQTT
Keller
Deye/SunSynk/Sol-Ark 3 Phase x 2 Inverter 2 - Work mode
select.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_work_mode
MQTT
Keller
Deye/SunSynk/Sol-Ark 3 Phase x 2 Load percentage
sensor.deye_sunsynk_sol_ark_3_phase_x_2_load_percentage
MQTT
Keller
Grid energ out
sensor.deye_sunsynk_sol_ark_3_phase_x_2_grid_energy_out
MQTT
Keller
Grid energy used
sensor.deye_sunsynk_sol_ark_3_phase_x_2_grid_energy_in
MQTT
Keller
Inv 2 Grid Power
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_grid_power
MQTT
Keller
Inv 2 Outp Freq
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_ac_output_frequency
MQTT
Keller
Inv1 Grid Volt
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_1_grid_voltage
MQTT
Keller
Inv1 Load Power
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_1_load_power
MQTT
Keller
Inv1 Load Power Essentials
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_1_load_power_essential
MQTT
Keller
Inv1 Load Power Essentials 1
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_1_load_power_essential_1
MQTT
Keller
Inv1 Load Power Essentials 2
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_1_load_power_essential_2
MQTT
Keller
Inv1 Load Power1
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_1_load_power_1
MQTT
Keller
Inv1 Load Power2
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_1_load_power_2
MQTT
Keller
Inv1 Load Power3
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_1_load_power_3
MQTT
Keller
Inv1 PV Power
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_1_pv_power
MQTT
Keller
Inv1 PV Power1
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_1_pv_power_1
MQTT
Keller
Inv1 PV Power2
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_1_pv_power_2
MQTT
Keller
Inv2 AC outp Volt
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_ac_output_voltage
MQTT
Keller
Inv2 Aux PV Power
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_auxiliary_pv_power
MQTT
Keller
Inv2 Load Power
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_load_power
MQTT
Keller
Inv2 Load Power Essentials
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_load_power_essential
MQTT
Keller
Inv2 Load Power Essentials1
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_load_power_essential_1
MQTT
Keller
Inv2 Load Power Essentials2
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_load_power_essential_2
MQTT
Keller
Inv2 Load Power Essentials3
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_load_power_essential_3
MQTT
Keller
Inv2 Load Power1
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_load_power_1
MQTT
Keller
Inv2 Load Power2
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_load_power_2
MQTT
Keller
Inv2 Load Power3
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_load_power_3
MQTT
Keller
Inv2 PV Power
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_pv_power
MQTT
Keller
Inv2 PV Power1
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_pv_power_1
MQTT
Keller
Inv2 PV Power2
sensor.deye_sunsynk_sol_ark_3_phase_x_2_inverter_2_pv_power_2
MQTT
Keller
Läuft
binary_sensor.sunsynk_deye_inverter_add_on_multi_lauft
Home Assistant Supervisor
Integration
Load Energie Woche
sensor.deye_sunsynk_sol_ark_3_phase_x_2_load_energy
MQTT
Keller
Load Power
sensor.deye_sunsynk_sol_ark_3_phase_x_2_load_power
MQTT
Keller
Netz Power
sensor.deye_sunsynk_sol_ark_3_phase_x_2_grid_power
MQTT
Keller
Neueste Version
sensor.sunsynk_deye_inverter_add_on_multi_neueste_version
Integration
PV Power
sensor.deye_sunsynk_sol_ark_3_phase_x_2_pv_power
MQTT
Keller
PV Wochen Energie
sensor.deye_sunsynk_sol_ark_3_phase_x_2_pv_energy
MQTT
Keller
Response
sensor.deye_sunsynk_sol_ark_3_phase_x_2_response
MQTT
Keller
Benutzer
sensor Compensation
sensor.deye_sunsynk_sol_ark_3_phase_x_2_grid_energy_out_compensation
Energie
sensor Cost
sensor.deye_sunsynk_sol_ark_3_phase_x_2_grid_energy_in_cost
Energie
Integration
SOC
sensor.deye_sunsynk_sol_ark_3_phase_x_2_battery_state_of_charge
MQTT
Keller
Sunsynk/Deye Inverter Add-on (multi) Update
update.sunsynk_deye_inverter_add_on_multi_update
Version
sensor.sunsynk_deye_inverter_add_on_multi_version
Integration
