When I’m working on modifying an automation, I copy an existing automation, add a version # to the name and disable the old automation. I also rename the old automations by adding " - disabled" at the end of the name so it’s easy to track what should and shouldn’t be running.
I currently have 10 automations with " - disabled" in the name.
When I restart HASS, 2 of them get re-enabled.
I’ve restarted several times and the same 2 are getting re-enabled.
These same 2 also seem to re-enable on their own. They actually re-enabled while I was typing this post.
