I’m trying this on my current setup but somehow its not working. I see the following error
WARNING:homeassistant.components.alexa:Received unknown intent ActivateSceneIntent
my alexa.yaml has the following config:
ActivateSceneIntent:
service: scene.turn_on
data_template:
entity_id: scene.{{ Scene | replace(" ", “_”) }}
speech:
type: plaintext
text: OK
my scenes.yaml
entities:
switch.living_room_tv:
state: on
Have you checked home-assistant.log for errors? If this is your first Alexa intent, it could be that you haven’t set it up correctly - in that case, it wouldn’t be available to HA.
Try posting using preformatted text to see if we can spot an issue.
And be sure that you’ve included that alexa.yaml in your main config (I know - basic - but it happens)
I’m loosing somewhere and I don’t know where. alexa: intents: ActivateSceneIntent: action: service: scene.turn_on data_template: entity_id: scene.{{ Scene | replace(" ", "_") }} speech: type: plaintext text: OK
When I ask Alexa she say hello but HASS error:
17-04-11 14:54:18 ERROR (MainThread) [homeassistant.core] Invalid service data for scene.turn_on: Entity ID scene. is an invalid entity id for dictionary value @ data[‘entity_id’]. Got ‘scene.’
Looks like a problem with the template but I don’t know where.
same here, i dont get an error though. i just get: 17-04-12 22:59:00 INFO (MainThread) [homeassistant.components.http] Serving /api/alexa to xx.xx.xx.xx (auth: True) in the log.
anything changed recently? i also dont get confirmation from alexa and it looks like this from the amazon developer console:
“version”: “1.0”,
“response”: {
“shouldEndSession”: true
“sessionAttributes”: {}
I really missed my random playlists. I have random music start my day as an alarm and I wanted the randomness back, so I thought I’d do some spelunking.
Since range still produced random numbers, I experimented with using that. Then I hit the Jinja docs to figure out the syntax for getting the length of a list…
hi, I was trying custom command to use with Alexa. It works when I try to test in Service Simulator you can find screenshot below. even it responds success command when I when I speak to Alexa “ask home assistant to turn on ac” but it does not trigger script. someone, please help me
alexa:
intents:
WhereAreWeIntent:
speech:
type: plaintext
text: >
{%- if is_state('device_tracker.ashu_ashu', 'home') and
is_state('device_tracker.afu_afu', 'home') -%}
You are both home, you silly
{%- else -%}
Afu is at {{ states("device_tracker.afu_afu") }}
and Ashu is at {{ states("device_tracker.ashu_ashu") }}
{% endif %}
LocateIntent:
service: notify.notify
data_template:
message: The location of {{ User }} has been queried via Alexa.
speech:
type: plaintext
text: >
{%- for state in states.device_tracker -%}
{%- if state.name.lower() == User.lower() -%}
{{ state.name }} is at {{ state.state }}
{%- elif loop.last -%}
I am sorry, I do not know where {{ User }} is.
{%- endif -%}
{%- else -%}
Sorry, I don't have any trackers registered.
{%- endfor -%}
card:
type: simple
title: Sample title
content: Some more content
RunScriptIntent:
service: script.turn_on
data_template:
entity_id: script.{{ Script | replace(" ", "_") }}
speech:
type: plaintext
text: !include alexa_confirm.yaml
I think that sample utterance might be your issue. I’m not sure that Alexa can extract {Script}ekn and just return the “Script” part of the phrase. I bet you’re not getting a value for Script that you expect. Perhaps do something where you can see the actual text value of Script, like create a notification.
In your home-assistant.log, you’ve likely got errors telling you that the script that it attempted to run does not exist.
I remember I used to have that problem way back in the beginning. I cant remember exactly what I did to fix it but it was in my intent/script that I had something off.
you just need to verify your syntax & indentations are all good.
at least you’ve passed a major hurdle! the alexa dev works!
@aimc
Are you still using this within the new auth setup? This Alexa skill is my last thing that needs to be moved over and I haven’t figured out how to do it.
