Some help to migrate ESPeasy to ESPhome
Hi All,
Can someone help me with follow.
I want do some actions based on state of sensor:
  # MOTION
  - platform: mqtt_subscribe
    name: "MQTT Listen - Motion"
    topic: homeassistant/motion/toilet
I want change neopixel color when this sensor state is 1 and change color again when state is 0
I get lots of things work now. Wondering if things can be shorter and smarter:
esphome:
esp8266:
  board: nodemcuv2
logger: # Enable logging
api: # Enable Home Assistant API
  encryption:
    key: "SNAP SKIP HIDDEN"
ota:
  password: "SNAP SKIP HIDDEN"
wifi:
  ssid: SNAP SKIP HIDDEN
  password: SNAP SKIP HIDDEN
  power_save_mode: none
  reboot_timeout: 30min
  fast_connect: true
mqtt:
  broker: 192.168.100.24
  username: SNAP SKIP HIDDEN
  client_id: esphome
  discovery: true
light:
  - platform: neopixelbus
    default_transition_length: 0s
    type: GRB
    variant: 800KBPS
    pin: GPIO2
    num_leds: 2
switch:
  - platform: gpio
    pin: D1
binary_sensor:
  - platform: gpio
    pin: D6
    on_press:
      - switch.toggle: switch1
      - if:
          condition:
            switch.is_on: switch1
          then:
            - light.turn_on:
                brightness: 100%
                red: 0%
                green: 100%
                blue: 0%
      - if:
          condition:
            switch.is_off: switch1
          then:
            - if:
                condition:
                  lambda: |-
                    return id(mqtt_listen_daytime).state > 0;
                then:
                  - light.turn_on:
                      brightness: 100%
                      red: 100%
                      green: 0%
                      blue: 0%
            - if:
                condition:
                  lambda: |-
                    return id(mqtt_listen_evening).state > 0;
                then:
                  - light.turn_on:
                      brightness: 100%
                      red: 100%
                      green: 0%
                      blue: 0%
            - if:
                condition:
                  lambda: |-
                    return id(mqtt_listen_kodi).state > 0;
                then:
                  - light.turn_on:
                      brightness: 100%
                      red: 93%
                      green: 0%
                      blue: 93%
            - if:
                condition:
                  lambda: |-
                    return id(mqtt_listen_appletv).state > 0;
                then:
                  - light.turn_on:
                      brightness: 100%
                      red: 100%
                      green: 0%
                      blue: 0%
            - if:
                condition:
                  lambda: |-
                    return id(mqtt_listen_tv).state > 0;
                then:
                  - light.turn_on:
                      brightness: 100%
                      red: 0%
                      green: 25%
                      blue: 53%
            - if:
                condition:
                  lambda: |-
                    return id(mqtt_listen_nintendo).state > 0;
                then:
                  - light.turn_on:
                      brightness: 100%
                      red: 36%
                      green: 28%
                      blue: 55%
  # SCENES
    name: "MQTT Listen - Guests"
    accuracy_decimals: 0
    topic: homeassistant/scenes/guests
    name: "MQTT Listen - Goodnight"
    topic: homeassistant/scenes/goodnight
    on_value:
      then:
        if:
          condition:
            lambda: 'return x > 0;'
          then:
            - light.turn_on:
                brightness: 100%
                red: 20%
                green: 31%
                blue: 9%
    name: "MQTT Listen - Daytime"
    topic: homeassistant/scenes/daytime
    on_value:
      then:
        if:
          condition:
          then:
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 0%
                blue: 0%
    name: "MQTT Listen - Evening"
    topic: homeassistant/scenes/evening
    on_value:
      then:
        if:
          condition:
          then:
            - light.turn_on:
                brightness: 100%
                red: 100%
                green: 0%
                blue: 0%
    name: "MQTT Listen - AppleTV"
    topic: homeassistant/scenes/appletv
    on_value:
      then:
        if:
          condition:
          then:
            - light.turn_on:
                brightness: 100%
                red: 55%
                green: 55%
                blue: 0%
    name: "MQTT Listen - Kodi"
    topic: homeassistant/scenes/kodi
    on_value:
      then:
        if:
          condition:
          then:
            - light.turn_on:
                brightness: 100%
                red: 93%
                green: 0%
                blue: 93%
    name: "MQTT Listen - Nintendo"
    topic: homeassistant/scenes/nintendo
    on_value:
      then:
        if:
          condition:
          then:
            - light.turn_on:
                brightness: 100%
                red: 36%
                green: 28%
                blue: 55%
    name: "MQTT Listen - tv"
    topic: homeassistant/scenes/tv
    on_value:
      then:
        if:
          condition:
          then:
            - light.turn_on:
                brightness: 100%
                red: 0%
                green: 25%
                blue: 53%
  # MOTION
    on_value:
      then:
        if:
          condition:
          then:
            - light.turn_on:
                brightness: 100%
                red: 0%
                green: 0%
                blue: 100%
          else:
            - if:
                condition:
                then:
                  - light.turn_on:
                      brightness: 100%
                      red: 0%
                      green: 100%
                      blue: 0%
            - if:
                condition:
                then:
                  - if:
                      condition:
                        lambda: |-
                      then:
                        - light.turn_on:
                            brightness: 100%
                            red: 100%
                            green: 0%
                            blue: 0%
                  - if:
                      condition:
                        lambda: |-
                      then:
                        - light.turn_on:
                            brightness: 100%
                            red: 100%
                            green: 0%
                            blue: 0%
                  - if:
                      condition:
                        lambda: |-
                      then:
                        - light.turn_on:
                            brightness: 100%
                            red: 93%
                            green: 0%
                            blue: 93%
                  - if:
                      condition:
                        lambda: |-
                      then:
                        - light.turn_on:
                            brightness: 100%
                            red: 100%
                            green: 0%
                            blue: 0%
                  - if:
                      condition:
                        lambda: |-
                      then:
                        - light.turn_on:
                            brightness: 100%
                            red: 0%
                            green: 25%
                            blue: 53%
                  - if:
                      condition:
                        lambda: |-
                      then:
                        - light.turn_on:
                            brightness: 100%
                            red: 36%
                            green: 28%
                            blue: 55%
