(some) icons no longer change with state change
First observed in 105.5, also observed in 106
zwave lights and tasmota lightbulbs classified as “light” properly change icon when state changes
but tasmota plugs and devices configured as “switch” do not…
switches are manually configured for mqtt in switches.yaml, which is included in main configuration.yaml, as i have done for years. Worked fine until 105.5, and not working in 106.
any ideas?
It was covered in the release notes for 105.
You need to check the docs for the lovelace cards that you use and look for “state_color: true”.
it was in the breaking changes for v105 and there have been a few threads about it since 105 was released.
ah thank you – not sure how i missed that.
