Some problems with HA core install on Armbian Linux
  1. I installed linux (Armbian 23.8.1 Jammy with Linux 6.1.50-current-rk322x) on the TV Box.
  2. Followed Installation in Python virtual environment - Home Assistant to install HA. I faced many errors by the way, and fixed some by manually install some of dependencies.
  3. Now HA is working fine, for my current needs, but I have some errors during startup, what may be not good.
And here is log:
home-assistant_xxx.log
2023-10-17 09:17:27.261 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration yandex_smart_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-10-17 09:17:27.267 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-10-17 09:17:27.273 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration xiaomi_miio_philipslight which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-10-17 09:17:27.278 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-10-17 09:36:41.704 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package ha-av==10.1.0: error: subprocess-exited-with-error
  × Getting requirements to build wheel did not run successfully.
  │ exit code: 1
  ╰─> [64 lines of output]
      Compiling av/utils.pyx because it changed.
      [1/1] Cythonizing av/utils.pyx
      Compiling av/stream.pyx because it changed.
      [1/1] Cythonizing av/stream.pyx
      Compiling av/plane.pyx because it changed.
      [1/1] Cythonizing av/plane.pyx
      Compiling av/packet.pyx because it changed.
      [1/1] Cythonizing av/packet.pyx
      Compiling av/option.pyx because it changed.
      [1/1] Cythonizing av/option.pyx
      performance hint: av/logging.pyx:232:5: Exception check on 'log_callback' will always require the GIL to be acquired. Possible solutions:
          1. Declare the function as 'noexcept' if you control the definition and you're sure you don't want the function to raise exceptions.
          2. Use an 'int' return type on the function to allow an error code to be returned.
      Error compiling Cython file:
      cdef const char *log_context_name(void *ptr) nogil:
          cdef log_context *obj = <log_context*>ptr
          return obj.name
      cdef lib.AVClass log_class
      log_class.item_name = log_context_name
      av/logging.pyx:216:22: Cannot assign type 'const char *(void *) except? NULL nogil' to 'const char *(*)(void *) noexcept nogil'. Exception values are incompatible. Suggest adding 'noexcept' to type 'const char *(void *) except? NULL nogil'.
      # Start the magic!
      # We allow the user to fully disable the logging system as it will not play
      # nicely with subinterpreters due to FFmpeg-created threads.
      if os.environ.get('PYAV_LOGGING') != 'off':
          lib.av_log_set_callback(log_callback)
      av/logging.pyx:351:28: Cannot assign type 'void (void *, int, const char *, va_list) except * nogil' to 'av_log_callback'. Exception values are incompatible. Suggest adding 'noexcept' to type 'void (void *, int, const char *, va_list) except * nogil'.
      Compiling av/logging.pyx because it changed.
      [1/1] Cythonizing av/logging.pyx
        File "/root/homeassistant/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
          main()
        File "/root/homeassistant/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
          json_out['return_val'] = hook(**hook_input['kwargs'])
        File "/root/homeassistant/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 118, in get_requires_for_build_wheel
          return hook(config_settings)
        File "/tmp/pip-build-env-d4vj_h2k/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 355, in get_requires_for_build_wheel
          return self._get_build_requires(config_settings, requirements=['wheel'])
        File "/tmp/pip-build-env-d4vj_h2k/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 325, in _get_build_requires
          self.run_setup()
        File "/tmp/pip-build-env-d4vj_h2k/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 507, in run_setup
          super(_BuildMetaLegacyBackend, self).run_setup(setup_script=setup_script)
        File "/tmp/pip-build-env-d4vj_h2k/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 341, in run_setup
          exec(code, locals())
        File "<string>", line 157, in <module>
        File "/tmp/pip-build-env-d4vj_h2k/overlay/lib/python3.10/site-packages/Cython/Build/Dependencies.py", line 1154, in cythonize
          cythonize_one(*args)
        File "/tmp/pip-build-env-d4vj_h2k/overlay/lib/python3.10/site-packages/Cython/Build/Dependencies.py", line 1321, in cythonize_one
          raise CompileError(None, pyx_file)
      Cython.Compiler.Errors.CompileError: av/logging.pyx
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
│ exit code: 1
╰─> See above for output.
[notice] A new release of pip is available: 23.1 -> 23.3
[notice] To update, run: python3 -m pip install --upgrade pip
2023-10-17 09:38:18.998 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package ha-av==10.1.0: error: subprocess-exited-with-error
  │ exit code: 1
          return obj.name
      # Start the magic!
          main()
        File "/tmp/pip-build-env-mtjth54e/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 355, in get_requires_for_build_wheel
        File "/tmp/pip-build-env-mtjth54e/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 325, in _get_build_requires
          self.run_setup()
        File "/tmp/pip-build-env-mtjth54e/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 507, in run_setup
        File "/tmp/pip-build-env-mtjth54e/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 341, in run_setup
        File "/tmp/pip-build-env-mtjth54e/overlay/lib/python3.10/site-packages/Cython/Build/Dependencies.py", line 1154, in cythonize
        File "/tmp/pip-build-env-mtjth54e/overlay/lib/python3.10/site-packages/Cython/Build/Dependencies.py", line 1321, in cythonize_one
      [end of output]
│ exit code: 1
2023-10-17 09:39:56.027 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package ha-av==10.1.0: error: subprocess-exited-with-error
  │ exit code: 1
          return obj.name
      # Start the magic!
          main()
        File "/tmp/pip-build-env-5kwikb4n/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 355, in get_requires_for_build_wheel
        File "/tmp/pip-build-env-5kwikb4n/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 325, in _get_build_requires
          self.run_setup()
        File "/tmp/pip-build-env-5kwikb4n/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 507, in run_setup
        File "/tmp/pip-build-env-5kwikb4n/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 341, in run_setup
        File "/tmp/pip-build-env-5kwikb4n/overlay/lib/python3.10/site-packages/Cython/Build/Dependencies.py", line 1154, in cythonize
        File "/tmp/pip-build-env-5kwikb4n/overlay/lib/python3.10/site-packages/Cython/Build/Dependencies.py", line 1321, in cythonize_one
      [end of output]
│ exit code: 1
2023-10-17 09:39:56.039 ERROR (MainThread) [homeassistant.setup] Setup failed for stream: Requirements for stream not found: ['ha-av==10.1.0'].
2023-10-17 09:39:58.545 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: xiaomi_miio, ffmpeg
2023-10-17 09:40:05.740 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: stream
2023-10-17 09:40:05.745 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: (DependencyError(...), 'Could not setup dependencies: stream')
2023-10-17 09:40:08.731 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for ble @ 192.168.1.221: Error connecting to ('192.168.1.221', 6053): [Errno 113] Connect call failed ('192.168.1.221', 6053) (SocketAPIError)
2023-10-17 09:40:10.221 WARNING (MainThread) [homeassistant.bootstrap] Support for the running Python version 3.10.12 is deprecated and will be removed in Home Assistant 2023.8; Please upgrade Python to 3.11
solved: full reinstall of the HA
