I wrote two new components, for eq3 MAX! thermostats using the Max!Cube and also for eq3 Bluetooth Smart thermostats.
Additionally, I fixed some homematic thermostat stuff, that was not threadsafe and errored out a lot, which is now much better in my version. Also, support for MAX! thermostats that are controlled via homegear.
The MAX!cube stuff I can no longer test because I flashed it to a CUN / CUL using a-culfw and am controlling it via homegear and homematic component now.
I would like to, but I can’t seem to get a real independent development environment running. Even if I use a virtualenv it interacts with my main HA installation.
