Some VeraPlus Z-Wave devices wrongly identified
I have my home assistant connected to VeraPlus via the integration and it works fine.
The only issue I have is that some of my RGB Led Strips (using Fibaro RGBW zwave devices) are identified in Home Assistant as just on-off light switches. This happens to just some RGB Led strips.
Any idea how I can fix it?
Thanks.
Have you set the id from switch to light?
Vera switch device - By default your switches will be added to Home Assistant as switches, however, if some of them are light switches, you can tell Home Assistant this by providing a list of light ids.
