Hi!
I have a situation and I don’t understand why is happening.
Two similar automations with the webhook trigger, one is working, one is not.
For the one which is not working, I get this error in the log:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/webhook/__init__.py:44
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 12:33:42 (3 occurrences)
Last logged: 12:41:51
[140204543761264] Error setting up trigger
[140204179446112] Error setting up trigger
File "/usr/src/homeassistant/homeassistant/components/webhook/trigger.py", line 55, in async_attach_trigger
async_register(
File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 44, in async_register
raise ValueError("Handler is already defined!")
ValueError: Handler is already defined!
Both automation, uses different webhook trigger, webhooks which are used only in these automations.
Any idea how to solve this?
Thank you in advance!
