- data: {}
service: switch.turn_on
alias: New Automation
condition:
- condition: state
entity_id: zwave.ge_unknown_type4f50_id3032
state: switch.turn_on
- event: sunset
platform: sun
- action: []
alias: ''
condition: []
trigger: []
try this one
automation:
platform: sun
event: sunset
offset: "-00:45:00"
condition:
condition: state
entity_id: group.all_devices
state: home
service: homeassistant.turn_on
entity_id: group.living_room_lights
Above example will wait for the sunset from sun platform and have to be 45 mins after sunset. Have to match the condition that group all devices are at home. To perform action turn on all group of light in the living room.
automation:
platform: sun
event: sunset
offset: "-00:04:00"
condition: []
condition: state
entity_id: switch.ge_unknown_type4f50_id3032_switch
yeap still turning on all lights
automation:
platform: sun
event: sunset
offset: "-00:04:00"
condition:
condition: state
state: off
try this one. this will turn on zwave switch 4 mins after sunset. condition if the zwave switch is off.
2018-01-04 04:33:15 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: expected a dictionary. Got OrderedDict([(‘homeassistant’, OrderedDict([(‘name’, ‘Boone Grove’), (‘latitude’, 41.353684), (‘longitude’, -87.133932), (‘elevation’, 715), (‘unit_system’, ‘imperial’), (‘time_zone’, ‘America/Chicago’), (‘customize’, OrderedDict([(‘zwave._’, OrderedDict([(‘friendly_name’, ’ outlet’)])), (‘switch.switch_2’, OrderedDict([(‘friendly_name’, ‘bedroom’)])), (‘switch.switch’, OrderedDict([(‘friendly_name’, ‘outlet’)])), (‘zwave.ecolink_doorwindow_sensor’, OrderedDict([(‘friendly_name’, 'driveway do… (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/
2018-01-04 04:33:15 WARNING (MainThread) [homeassistant.components.group] Group ‘all_automations’ doesn’t exist!
automation:
platform: sun
event: sunset
offset: "-00:04:00"
condition:
condition: state
entity_id: <== put the entityy_id of the siwtch
state: off
entity_id: <=== put the entity_id of the switch
I don’t know your switch name. You have to put the right entity_id
No luck so far? I am also after a solution to this apparently simple one (to others)!
Cheers,
Did you get the weather to work yet?
Nope. Still on motion sensor!
ok so the trick is to add all sensors: under one group like so.
indent preformatted text by 4 spaces
platform: yweather
monitored_conditions:- weather
- weather_current
- temp_min
- temp_max
- wind_speed
- pressure
- visibility
- humidity
- temperature
platform: yweather
forecast: 1
- temp_min
- temp_max
platform: yweather
forecast: 2
- temp_min
- temp_max
platform: yweather
forecast: 3
- temp_min
- temp_max
platform: ‘darksky’
api_key: api key
monitored_conditions:- summary
- icon
- nearest_storm_distance
platform: moon
Your config is missing a line right at the top.
Add
homeassistant:
to the first line before the name: Boone Grove
