Hi guys,
Having some trouble with HA.
After 2-3 days HA randomly stops working/getting slow. HA isn’t responding via SSH/Samba/UI.
1-30 minutes later HA is ‘back’, it started (not restarted!) itself. The host keeps working, but HA not. When back, I open the logfiles and find only the logs mentioned in this post. The homeassistant.log doesn’t show anything interesting right now (because of restart, it’s cleared itself).
I need some help figuring this one out. If I can, somehow, do some little digging that will help. I’ve searched every forum a couple of times already.
HA-info
Setup is running on a rpi 3b, current version of HA is 0.93.1.
Running hass.io 2.11, supervisor 164.
Previous versions had the same issue.
Hardware attached
RFLink USB, Z-Wave Aeonlabs USB-stick, DSMR USB
A lot of Z-Wave devices are attached
6 camera’s via stream, configured as camera’s
Full setup (May 29th) : HA up-and-running & thank you guys
Full configuration.yaml is homeassistant: name: !secret name latitude: !secret latitude longitude: - Pastebin.com
Below is a previous log, a second reply contains one from May 31th.
19-04-17 10:33:54 WARNING (SyncWorker_1) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost 19-04-17 10:33:54 WARNING (SyncWorker_7) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost 19-04-17 10:33:55 WARNING (SyncWorker_14) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost 19-04-17 10:33:55 WARNING (SyncWorker_6) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost 19-04-17 10:33:55 WARNING (SyncWorker_7) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost 19-04-17 10:33:55 WARNING (SyncWorker_17) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost 19-04-17 10:33:55 WARNING (SyncWorker_15) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost 19-04-17 10:33:55 WARNING (SyncWorker_9) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost 19-04-17 10:33:55 WARNING (SyncWorker_1) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost 19-04-17 10:33:55 WARNING (SyncWorker_19) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 ERROR (MainThread) [hassio.homeassistant] Error on call http://172.30.32.1:8123/api/: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused] 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home Assistant 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (SyncWorker_11) [urllib3.connectionpool] Connection pool is full, discarding connection: localhost 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker! 19-04-17 10:33:56 ERROR (MainThread) [hassio.utils] Can't execute start while a task is in progress 19-04-17 10:33:56 INFO (SyncWorker_12) [hassio.docker.interface] Start homeassistant/raspberrypi3-homeassistant 19-04-17 10:33:57 INFO (MainThread) [hassio.addons] Load add-ons: 56 all - 0 new - 0 remove 19-04-17 10:34:33 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
