About seven days ago I was playing around with home assistant OS on an SSD directly in a laptop and was playing with frigate and my two cameras wich are Ezviz were working fine with RTSP and were working also when in config file as generic and ffpg. Now I did a fresh install on the SSD and i am now concentrating on making my home smart even if I am not. I have finished all my other stuff zigbee integration all working well so I get back to the cameras they no longer work via RTSP I get an error that I can not find out about anywhere. Sorry tell a lie I can find it regarding all other devices but not cameras. It says “this entity camera.dave dose not have a unique i.d” and I have tried every thing apart from a fresh install.
Welcome @St1flerSteve
Could you share the error you get?
I assume you’ve found the error in Settings -> System -> Log
, correct?
If the message you get is that the entity does not have a unique_id, I’m guessing you were trying to edit details about the camera? This is not an error, it just means you cannot edit the name or other details. Not all integrations provide an unique id that enables this.
But what was the thing you were trying to achieve doing this?
Just run it as a generic camera I was not trying to edit setting just add it as an entity.
And also for some reason using it in motion eye it now says it’s not rtsp supported however it is through VLC player and on my network
