Is it possible to use a workaround in a script to open/close covers? for now the Somfy API is unreliable. Frequently the Somfy server is unreachable so you can’t activate the covers.
So I also want to use the logbook status to activate the covers, for example:
If the logbook status cover is “opened/closed” than it is possible to execute the script, if the logbook status is “cover unreachable” then it wait a few minutes for logbook status “cover opened/closed”.
Via HACS you can install the Somfy Tahoma integration which doesn’t make use of the API, but of the tahomalink website (works with a Conexxoon as well). It is much more reliable and your idea won’t be needed anymore
Although with a Connexoon you cannot login to the tahomalink website, it will still work with a connexoon (same situation here). Had the same hesitation, but is working fine for over a year know (as long as Somfy won’t block it).
