I want to migrate from openHAB to Homeassistant and I was using the RFXtrx433E without no problem in openHAB for more than 10 years.
I tried to convert the device Id I was using under openHAB to the format Homeassistant wants, and finally the code was accepted, when adding the event code in UI. But I cannot control the device. Nothing happens. What can I do, to find the problem? Any Ideas?
My configuration in openHAB looks like this:
Bridge rfxcom:bridge:usb0 [ serialPort="/dev/rfxtrx0", enableLighting4="true" ] {
Thing rfy e06d7fb4 [deviceId="65801.1", subType="RFY"]
This gives me the event code: 071a00000101b901
I added this via the configure option in the integration settings page and i got finally this here:
Here is the diag data, where you can see, that the device was added.
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2024.11.0",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.12.4",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Berlin",
"os_name": "Linux",
"os_version": "6.6.54-haos",
"supervisor": "2024.11.2",
"host_os": "Home Assistant OS 13.2",
"docker_version": "27.2.0",
"chassis": "vm",
"run_as_root": true
"custom_components": {
"spook": {
"documentation": "https://spook.boo",
"version": "3.1.0",
"requirements": []
"hacs": {
"documentation": "https://hacs.xyz/docs/configuration/start",
"version": "2.0.1",
"requirements": [
"aiogithubapi>=22.10.1"
"integration_manifest": {
"domain": "rfxtrx",
"name": "RFXCOM RFXtrx",
"codeowners": [
"danielhiversen",
"elupus",
"RobBie1221"
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/rfxtrx",
"iot_class": "local_push",
"loggers": [
"RFXtrx"
"requirements": [
"pyRFXtrx==0.31.1"
"is_built_in": true,
"overwrites_built_in": false
"setup_times": {},
"data": {
"entry": {
"created_at": "2024-11-07T20:37:28.387804+00:00",
"data": {
"host": null,
"port": null,
"device": "/dev/serial/by-id/usb-RFXCOM_RFXtrx433_A1XR54VU-if00-port0",
"automatic_add": true,
"devices": {
"0a5203008101008c3c0069": {
"device_id": [
"52",
"3",
"81:01"
"0a520101f20100de330150": {
"device_id": [
"52",
"1",
"f2:01"
"0d03010143ad7ab5f5ff4be007a4": {
"device_id": [
"3",
"1",
"Undecoded"
"0a520702280e0043390159": {
"device_id": [
"52",
"7",
"28:0e"
"0a5207032d0e00d7490360": {
"device_id": [
"52",
"7",
"2d:0e"
"0903100a257ffbf3fffe": {
"device_id": [
"3",
"10",
"Undecoded"
"0c03039240dfabd5fffdbadfba": {
"device_id": [
"3",
"3",
"Undecoded"
"0f0309bc526cd0a7049f2f1055303100": {
"device_id": [
"3",
"9",
"Undecoded"
"0f030873578aec138160041470913300": {
"device_id": [
"3",
"8",
"Undecoded"
"09130071fb822000f350": {
"device_id": [
"13",
"0",
"fb8220"
"0913007b93c88c016950": {
"device_id": [
"13",
"0",
"93c88c"
"091300beaedcc701e650": {
"device_id": [
"13",
"0",
"aedcc7"
"071a00000100e901": {
"device_id": [
"1a",
"0",
"0100e9:1"
"off_delay": 1,
"venetian_blind_mode": "Unknown"
"protocols": [
"oregon",
"lighting4",
"ac",
"adlightwave",
"arc",
"aeblyss",
"rsl",
"rubicson",
"undecoded",
"visonic",
"proguard",
"mertik",
"meiantech",
"lacrosse",
"keeloq",
"imagintronix",
"homeeasy",
"homeconfort",
"hideki",
"fs20",
"fineoffset",
"byronsx",
"blindst1234",
"blindst0",
"ati",
"x10"
"discovery_keys": {},
"disabled_by": null,
"domain": "rfxtrx",
"entry_id": "01JC45HA636RDV0VR1V48DGS86",
"minor_version": 1,
"modified_at": "2024-11-08T05:45:43.548418+00:00",
"options": {},
"pref_disable_new_entities": false,
"pref_disable_polling": false,
"source": "user",
"title": "RFXTRX",
"unique_id": "rfxtrx",
"version": 1
