Just installed a Somfy cover. The intergration went smooth but the cover is unavailable every other minute. I already figured out that the problem is probably caused by an endless loop of commands towards the cover as shown in the picture below. Any suggestions on how to solve this?
Unfortunately this is a known issue ( Somfy disconnects every 2 minutes · Issue #50815 · home-assistant/core (github.com)) caused by Somfy’s instable API.
In the mean-time you can use the custom integration (GitHub - iMicknl/ha-tahoma: Custom component for Home Assistant to interact with smart devices via Somfy TaHoma or other OverKiz based API's.) that uses that tahomalink.com API which has more features and is more stable…
Thank you so much! It worked!
