Somfy Hub Comparison
Can someone tell me what the difference is between the Somfy Connexoon Hub and Somfy TaHoma Smart Hub?
I am going to be buying smart blinds from 247blinds.co.uk and want to be able to control these via Home Assistant
Connexoon is enough to integrate with HA via TaHoma custom integration.
I use connexoon and it works perfectly.
I have gate drive and exterior window shutters.
You could probably use the RFXCOM Rfxtrx device, if you’re a bit tech-savy?
http://www.rfxcom.com/WebRoot/StoreNL2/Shops/78165469/MediaGallery/Downloads/RFXtrx_User_Guide.pdf
That is depending on the kind of motor the blinds will have. An I/O motor cannot be managed by the RFXCOM device. Then you require either an Connexoon or Tahoma box. The main difference between both is the number of devices that can be managed…
