sleepymaxx
(Sleepymaxx)
December 13, 2023, 11:07pm
1
In our House are Blinds and Shutters installed - controlled by a Somfy IB / IB+ system. BJ of our House is 2011.
Somfy is the controlling unit for the sunscreens and the rollos - there´s a automatic Wind/Sun and a chronological central Somfy unit installed.
For us it´s working fine but as always there are some improvements to go for:
Steering by Home Assistant
Getting the Sunscreen to anonther level: make the blinds shut more/less according to the anzimuth of the sun automatically
Steering all togehter by home Assistant integrated sensors - to get a better and more automatic sun/blind cover than the automatic ones.
How to go:
Get a esp32 / esp8266 D1Mini
(im using always the mini versions because they better fit in these housings)
Get a esp32 4 chanel Relais module
Have some soldering / low volt wiring / tools by hand
Now the Funny Part: wiring your 4 Relay Module to esp 32 D1Mini:
Go from Ground to Ground on your ESP8266
Go from VCC to 5V on your ESP8266
Go from IN1 (Relay1) to RX (GPIO3)
Go from IN2 (Relay2) to D2 (GPIO4)
Go from IN3 (Relay3) to D1 (GPIO5)
Go from IN4 (Relay4) to D6 (GPIO12)
Second Part: Wiring your relay module to your Soliris Ib: (in our House this is originally only installed for our Blinds)
Go from relais module K1 common pin to Soliris IB Steuerleitung Gemeinsamer C
Go from relais moulde K1 normally open pin to Soliris IB Steuerleitung AUF
Go from relais module K2 common pin to Soliris IB Steuerleitung Gemeinsamer C
Go from relais module K2 normally open pin to Soliris IB Steuerleitung AB
Third Part: Wiring your relay module to your Chronis IB L comfort:
(in our House this is originally only installed for our Shutters)
Go from relais module K3 common pin to Chronis IBLcomfort to Steuerleitung Gemeinsamer C
Go from relais module K3 normally opend pin to Chronis IBLcomfort to Steuerleitung AUF
Go from relais module K4 common pin to Chronis IBLcomfort to Steuerleitung Gemeinsamer C
Go from relais module K4 normally opend pin to Chronis IBLcomfort to
Steuerleitung AB
Install in your Home Assistant ESPHome Card your esp8266 and config it:
esphome:
friendly_name: Rolläden/Jalousien
esp8266:
board: esp01_1m
# Enable logging
# Enable Home Assistant API
api:
encryption:
key: " your encryption here "
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "your ssid here"
password: "your pw here"
captive_portal:
logger:
binary_sensor:
switch:
- platform: gpio
pin:
number: GPIO3
inverted: true
icon: "mdi:window-shutter-open"
# on_turn_on:
# - delay: 0.3s
# - switch.turn_off: open_switch_j
internal: true
- platform: gpio
pin:
number: GPIO4
inverted: true
name: "Jalousie schließen"
icon: "mdi:window-shutter"
# on_turn_on:
# - delay: 0.3s
# - switch.turn_off: close_switch_j
internal: true
- platform: gpio
pin:
number: GPIO5
inverted: true
icon: "mdi:garage-open"
# on_turn_on:
# - delay: 0.3s
# - switch.turn_off: open_switch_r
internal: true
- platform: gpio
pin:
number: GPIO12
inverted: true
name: "Rolladen schließen"
icon: "mdi:garage"
# on_turn_on:
# - delay: 0.3s
# - switch.turn_off: close_switch_r
internal: true
cover:
open_action:
# Cancel any previous action
# Turn the OPEN switch on briefly
- switch.turn_on: open_switch_j
- delay: 0.3s
close_action:
- switch.turn_on: close_switch_j
- delay: 0.3s
stop_action:
- delay: 0.3s
optimistic: true
assumed_state: true
icon: "mdi:blinds-horizontal"
open_action:
- switch.turn_on: open_switch_r
- delay: 0.3s
close_action:
- switch.turn_on: close_switch_r
- delay: 0.3s
stop_action:
- delay: 0.3s
optimistic: true
assumed_state: true
icon: "mdi:roller-shade"
Reboot HA and configure your new Integration ESPHOME Rolläden/Jalousien: You should get a new EntityCard:
Last Part: (but most Funny) - get your automation done for the automatic angel of your Blinds by azimut and sun standig level:
justbaj
(Dan)
February 4, 2024, 9:34am
2
thanks to @sleepymaxx for the explanations.
I’ve done the same thing with a 2 channel relay (2CH) and a wifi node mcu 8266 (cp2120 driver)
how to connect the pins from the wifi-modul to the relay:
Vin (wifi modul) → VCC (relay modul), you need Vin because of the 5V
GND (wifi modul) → GND (relay modul)
D1 (wifi modul) → IN1 (relay modul)
D2 (wifi modul) → IN2 (relay modul)
how to connect the relay modul with the somfy izymo transmitter F-74300:
S1 (somfy, green cable) → NO2 (relay modul, normally open)
S2 (somfy, yellow cable) → NO1 (relay modul, normally open)
COM (somfy, white cable) → COM2 (relay modul)
COM2 (relay modul) → COM1 (relay modul) connect these two COM pins together on the relay modul
my yaml config (without wifi config)
switch:
- platform: gpio
# D1
pin:
number: GPIO5
inverted: true
- platform: gpio
# D2
pin:
number: GPIO4
inverted: true
cover:
open_action:
- switch.turn_off: relaydown
- switch.turn_on: relayup
- delay: 1s
- switch.turn_off: relayup
close_action:
- switch.turn_on: relaydown
- delay: 1s
stop_action:
- delay: 1s
optimistic: true
assumed_state: true
redone my whole ESP-Home Configuration due to lack of positioning my Blinds correctly as i need:
i want to steer the whole heigth of my Blinds as well as the angle of shutting. so i got this in ESP HOME:
esphome:
friendly_name: Jalousien
esp8266:
board: esp01_1m
# Enable logging
api:
encryption:
key: "xxx.xxx.xxx
ota:
wifi:
fast_connect: off
power_save_mode: none
ap:
ssid: "xxx.xxx.xxx.xxx""
password: "xxx.xxx.xxx"
captive_portal:
- platform: wifi_signal
name: "${friendly_name} wifi_signal"
update_interval: 60s
logger:
binary_sensor:
external_components:
- source: github://klaudiusz223/esphome@tilt-cover
components: [ time_based_tilt ]
switch:
- platform: gpio
disabled_by_default: true
pin:
number: GPIO4
mode:
output: true
inverted: true
- platform: gpio
pin:
number: GPIO3
mode:
output: true
inverted: true
- platform: gpio
pin:
number: GPIO12
mode:
output: true
inverted: true
- platform: gpio
pin:
number: GPIO5
mode:
output: true
inverted: true
cover:
- id: cover_01
platform: time_based_tilt
open_duration: 49700 ms
close_duration: 48700 ms
inertia_open_time: 105 ms
tilt_open_duration: 930 ms
inertia_close_time: 105 ms
tilt_close_duration: 900 ms
interlock_wait_time: 105 ms
recalibration_time: 1500ms
assumed_state: true
close_action:
- switch.turn_on: blind_01_relay_down
open_action:
- switch.turn_on: blind_01_relay_up
stop_action:
- delay: 105 ms
- switch.turn_off: blind_01_relay_up
- switch.turn_off: blind_01_relay_down
- id: cover_02
assumed_state: true
close_action:
- switch.turn_on: blind_02_relay_down
open_action:
- switch.turn_on: blind_02_relay_up
stop_action:
- delay: 105 ms
- switch.turn_off: blind_02_relay_up
- switch.turn_off: blind_02_relay_down
The whole overwork and idea belongs to : github://klaudiusz223/esphome@tilt-cover
i only changed the timings of the Jalousies to my needs
due to this overhaul i was able to set up two differnt automations for the passing blinds of my House - one of them goes to the south the other goes to the West…
South:
alias: Jalousie-Süden
description: ""
- platform: numeric_state
entity_id:
- sensor.vbc702_s_outside_temperature
above: 19
for:
hours: 0
minutes: 5
seconds: 0
condition:
- condition: sun
before: sunset
after: sunrise
- condition: or
conditions:
- condition: state
entity_id: weather.forecast_langenmaier
attribute: cloud_coverage
state: sunny
- condition: state
state: partlycloudy
- condition: state
state: cloudy
- type: is_value
condition: device
device_id: 11b09e741d6b77c28d124b587c9283c3
entity_id: 86642053d6587b36622f3338b59ac581
domain: sensor
above: 130
below: 270
- service: cover.open_cover
metadata: {}
data: {}
entity_id: cover.jalousien_jalousie_sued
- delay:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
- choose:
- conditions:
- condition: time
before: "13:00:00"
sequence:
- service: cover.close_cover
metadata: {}
data: {}
- delay:
hours: 0
minutes: 0
seconds: 52
milliseconds: 0
- service: cover.stop_cover
metadata: {}
data: {}
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- conditions:
- condition: time
after: "13:00:00"
sequence:
metadata: {}
data: {}
- delay:
hours: 0
minutes: 0
seconds: 36
milliseconds: 0
metadata: {}
data: {}
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- choose:
- conditions:
- type: is_value
condition: device
entity_id: 83dcfe7101aa5dfb32d415cc5aded269
domain: sensor
above: 35
below: 100
sequence:
- service: cover.set_cover_tilt_position
metadata: {}
tilt_position: 100
entity_id:
- cover.jalousien_jalousie_sued
- conditions:
- type: is_value
condition: device
domain: sensor
below: 35
above: 25
sequence:
metadata: {}
tilt_position: 80
- conditions:
- type: is_value
condition: device
domain: sensor
below: 25
above: 15
sequence:
metadata: {}
tilt_position: 60
- conditions:
- type: is_value
condition: device
domain: sensor
below: 15
above: -15
sequence:
metadata: {}
tilt_position: 40
enabled: true
- repeat:
sequence:
- delay:
hours: 0
minutes: 15
seconds: 0
milliseconds: 0
- choose:
- conditions:
- condition: or
conditions:
- condition: numeric_state
entity_id: sensor.vbc702_s_outside_temperature
above: 30
entity_id: sensor.wasseruhr_esp_temperature_inside
above: 25
sequence:
metadata: {}
data: {}
entity_id:
- delay:
hours: 0
minutes: 0
seconds: 48
milliseconds: 0
metadata: {}
data: {}
- conditions:
- type: is_value
condition: device
domain: sensor
above: 35
below: 100
sequence:
- service: cover.open_cover_tilt
entity_id:
data: {}
- conditions:
- type: is_value
condition: device
domain: sensor
below: 35
above: 25
sequence:
metadata: {}
tilt_position: 80
- conditions:
- type: is_value
condition: device
domain: sensor
below: 25
above: 15
sequence:
metadata: {}
tilt_position: 60
- conditions:
- type: is_value
condition: device
domain: sensor
below: 15
above: -15
sequence:
metadata: {}
tilt_position: 40
enabled: true
until:
- condition: or
conditions:
- type: is_value
condition: device
domain: sensor
above: 280
below: 18.5
metadata: {}
data: {}
- delay:
hours: 0
minutes: 0
seconds: 49
milliseconds: 0
metadata: {}
data: {}
mode: single
West:
alias: Jalousie-Westen
description: ""
entity_id:
above: 19
for:
hours: 0
minutes: 10
seconds: 0
condition:
- condition: sun
before: sunset
after: sunrise
- condition: or
conditions:
- condition: state
state: sunny
- condition: state
state: partlycloudy
- condition: state
state: cloudy
- type: is_value
condition: device
domain: sensor
above: 175
below: 307
metadata: {}
data: {}
entity_id: cover.jalousien_jalousie_west
- delay:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
metadata: {}
data: {}
entity_id:
- cover.jalousien_jalousie_west
- delay:
hours: 0
minutes: 0
seconds: 52
milliseconds: 0
metadata: {}
data: {}
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- choose:
- conditions:
- type: is_value
condition: device
domain: sensor
above: 35
below: 100
sequence:
metadata: {}
tilt_position: 100
- conditions:
- type: is_value
condition: device
domain: sensor
below: 35
above: 25
sequence:
metadata: {}
tilt_position: 80
- conditions:
- type: is_value
condition: device
domain: sensor
below: 25
above: 15
sequence:
metadata: {}
tilt_position: 60
- conditions:
- type: is_value
condition: device
domain: sensor
below: 15
above: -15
sequence:
metadata: {}
tilt_position: 40
enabled: true
- repeat:
sequence:
- delay:
hours: 0
minutes: 15
seconds: 0
milliseconds: 0
- choose:
- conditions:
- condition: or
conditions:
above: 30
above: 25
sequence:
metadata: {}
data: {}
- delay:
hours: 0
minutes: 0
seconds: 48
milliseconds: 0
metadata: {}
data: {}
- conditions:
- type: is_value
condition: device
domain: sensor
above: 35
below: 100
sequence:
metadata: {}
tilt_position: 100
- conditions:
- type: is_value
condition: device
domain: sensor
below: 35
above: 25
sequence:
metadata: {}
tilt_position: 80
- conditions:
- type: is_value
condition: device
domain: sensor
below: 25
above: 15
sequence:
metadata: {}
tilt_position: 60
- conditions:
- type: is_value
condition: device
domain: sensor
below: 15
above: -15
sequence:
metadata: {}
tilt_position: 40
enabled: true
until:
- condition: or
conditions:
- condition: sun
before: sunset
after: sunset
after_offset: "5"
below: 18.5
metadata: {}
data: {}
- delay:
hours: 0
minutes: 0
seconds: 50
milliseconds: 0
metadata: {}
data: {}
mode: single
With this setup i´m able to automatically steer the south/west Blinds accordingly to Sun Anzimuth/Elevation/Temperature Outside/Inside /the Radiation level /the amount of Light inside the House/ my Weather Forecast and so on… Also with the new Programming of my ESP HOME device im able to steer furthermore the percentage of closing/opening as well as the angle of the shading blinds.
