Somfy integration behaves weird
Hi.
I am new to Home Assistant. It runs on RPi4. I have enabled Somfy integration via the wizard that appeared automatically based on local network detection of Tahoma Premium gateway. I enabled the ingeration, everything seemed to be fine. Until I tried using it…
It behaves just weird. I have a scene that is supposed to close window blinds defined like this
- id: '1637227670160'
  entities:
    cover.zaluzie_koupelna:
      current_position: 0
      current_tilt_position: 0
      friendly_name: Zaluzie-Koupelna
      supported_features: 255
      device_class: blind
      state: closed
    cover.zaluzie_loznice_fix:
      current_position: 0
      friendly_name: Zaluzie-Loznice-Fix
      device_class: blind
      state: closed
    cover.zaluzie_loznice_otviratelne:
      current_position: 0
      friendly_name: Zaluzie-Loznice-Otviratelne
      device_class: blind
      state: open
    cover.zaluzie_pokoj_fix:
      current_position: 0
      friendly_name: Zaluzie-Pokoj-Fix
      device_class: blind
      state: open
    cover.zaluzie_pokoj_otviratelne:
      current_position: 0
      friendly_name: Zaluzie-Pokoj-Otviratelne
      device_class: blind
      state: open
    cover.zaluzie_portal_fix:
      current_position: 0
      friendly_name: Zaluzie-Portal-Fix
      device_class: blind
      state: open
    cover.zaluzie_portal_otviratelne:
      current_position: 0
      friendly_name: Zaluzie-Portal-Otviratelne
      device_class: blind
      state: open
  icon: mdi:blinds
I run the scene and end up with this. Two blinds closed partially at the same position. Two blinds closed partially in a different position than the other two. Two blinds untouched and kept fully open. One blind closed as expected.
And in the log I see this
Logger: homeassistant.components.websocket_api.http.connection
Source: components/somfy/cover.py:182
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 14:35:41 (1 occurrences)
Last logged: 14:35:41
[547465353056] message: internal_error, data: None
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 185, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1495, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1530, in _execute_service
    await handler.job.target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
    await self.hass.helpers.service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 667, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 863, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 704, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/homeassistant/scene.py", line 314, in async_activate
    await async_reproduce_state(
  File "/usr/src/homeassistant/homeassistant/helpers/state.py", line 116, in async_reproduce_state
    await asyncio.gather(
  File "/usr/src/homeassistant/homeassistant/helpers/state.py", line 110, in worker
    await platform.async_reproduce_states(  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/cover/reproduce_state.py", line 125, in async_reproduce_states
  File "/usr/src/homeassistant/homeassistant/components/cover/reproduce_state.py", line 107, in _async_reproduce_state
    task.result()
    await coro
    await result
  File "/usr/src/homeassistant/homeassistant/components/cover/__init__.py", line 330, in async_close_cover_tilt
    await self.hass.async_add_executor_job(
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
  File "/usr/src/homeassistant/homeassistant/components/somfy/cover.py", line 182, in close_cover_tilt
    self._cover.orientation = 100
  File "/usr/local/lib/python3.9/site-packages/pymfy/api/devices/blind.py", line 17, in orientation
    self.send_command(command)
  File "/usr/local/lib/python3.9/site-packages/pymfy/api/devices/base.py", line 19, in send_command
    self.api.send_command(self.device.id, command)
  File "/usr/local/lib/python3.9/site-packages/pymfy/api/somfy_api.py", line 58, in send_command
    response = self.post(f"/device/{device_id}/exec", json=command)
  File "/usr/local/lib/python3.9/site-packages/pymfy/api/somfy_api.py", line 89, in post
    return self._request("post", path, json=json)
  File "/usr/local/lib/python3.9/site-packages/pymfy/api/somfy_api.py", line 134, in _request
    self._check_response(response)
  File "/usr/local/lib/python3.9/site-packages/pymfy/api/somfy_api.py", line 147, in _check_response
    raise CLIENT_ERROR.get(message, ClientException)(response.json())
pymfy.api.error.ClientException: message: internal_error, data: None
What is wrong? Is it a problem in Tahoma? Or Home Assistant? Or my configuration is wrong?
