Hi, newbie here, so please be gentle… I know lots has already been written about Somfy integration, but I can find anything that helps me out.
I’ve just started using HA with a Zwave.me UZB Z-Wave controller. Today I got my new awning, with a Somfy IO motor (ordered before I even thought about HA).
I found the Somfy integration and installed it just as described in the documentation (which didn’t mention the need for a Connexoon or TaHoma). Hopefully restarted HA, but sadly no Somfy devices were discovered. Double checked everything, but everything seems to be fine.
So, do I need a Connexoon/TaHoma after all? They seem a bit expensive just to control the awning. Or do I need to do something to pair the IO motor to HA?
Thanks. I had a quick lookaround, RFX controllers aren’t as cheap as Z-Wave models, but cheaper than Somfy controllers. Probably more robust too.
But from what I read, it works with Somfy RTS motors. Does it support IO motors too?
If one opens the spec, he will find that Somfy IO works on frequency 868, while Somfy RTS works on 433,42. Not only the frequency matters, but also the protocol which is (as far as I know at the moment) not yet hacked.
