I’m trying to add the Somfy Integration with ‘configuration.yaml’ mode, but each time I am redirected to Somfy website, it says :
Une erreur est survenue
Veuillez réessayer. Si le problème persiste, veuillez contacter le support technique.
I have add my apps in somfy developper website, put my hass url, and define consumer key /. secret in my configuration. Am I the only one in that case ?
Somfy doesn’t expose their alarm through the API. About the Thermostat, the library behind the component is ready. But I still have to integrate it within home assistant. The mapping is not obvious. I will need help. You can contact me directly by message in French.
Je suis équipé d’un home assistant d’une alarme Somfy Home Alarm.
J’aurais souhaité connaitre votre astuce IFTTT pour recevoir l’état de mon alarme dans HA.
Pouvez vous m’aider ?
Merci bcp, je désespère
IFTTT is not more free if you need more than 3 actions. I need 8.
Looking for a solution with google integration.
Does anyone know if we can get devices from google assistant as it is for Homekit ?
