Somfy mylink integration
I’ve been trying to get my Somfy mylink integration to report the state of the window shades. I know with Somfy RTS and the mylink, there is no real way to relay back from the shade to the mylink what the actual state of the shade is in but the state could be assumed if only using home-assistant to control the shades. I know in the SOMFY API integration (not the somfy mylink integration) there is an optimistic option, however there is not one for the mylink.
I tried to figure out how to integrate the somfy mylink into the somfy developers api, but can’t seem to find anything on how to access the synergy api or the mylink from the developers api. I would then just use the Somfy API to integrate in, however, after reading a little more into this it looks like the developers api only integrates in with TaHoma or Connexoon.
Does anyone have any idea how to get the shades to update from an “unknown” state? If anyone has any insight into this, I would greatly appreciate it. Thanks!
Hey @jamieboy05, any luck tracking the status of your shades (using the optimistic option)? I’ve been tinkering without success…
I have not had any luck. I recently relocated across the country from St. Louis to Norfolk VA this last November with my husband. His work relocated us. Things are just now starting to balance back out again. I have a new setup at our new home, but I’m having problems even getting the Somfy App to even work on my phone. I recently got an iphone 12 pro max. Luckily, the shades I already had work with the new house, so I installed them, got my remote re programmed and went to the app to try to set it up and I can’t seem to click the edit button.
