Somfy/Overkiz Integration in 2022.02
Is the Overkiz/Somfy Integration In HACS the same as the official one released in 2022.02? They are running both now, I wonder If I should get rid of the HACS or the official one?
Although the HACS one is providing more entities, I wonder why?
OK, reading helps actually…:smiley:
“Home Assistant 2022.2 will have the Overkiz (by Somfy) integration available in core. Most platforms are supported, except for siren, climate and water heater. Please use one of the integrations (core vs custom), to avoid calling Somfy’s servers from two separate integrations and to avoid authentication issues.”
Great that you already found your answer! :smiley: We haven’t been able to port all our entities to core in time indeed, you can track our progress here.
