Somfy Roller shutter replacement
I have a 500w manual Somfy Roller Shutter that I want to replace with something that is Home Assistant controllable. Does anyone know some compatible controllers of solutions?
Somfy RTS can be controlled by the RFXtrx433XL. With the same RFXtrx433XL you are able receive and control a lot of other devices operating at 433.92MHz. The list of supported devices is in the RFXtrx User Guide available at http://www.rfxcom.com/WebRoot/StoreNL2/Shops/78165469/MediaGallery/Downloads/RFXtrx_User_Guide.pdf.
Note: Somfy IO operates at 868MHz and cannot be used.
