Somfy RTS awning - D1 mini homebrew solution
I have a friend who has a Somfy awning and didnt want to spend the couple hundred dollars or so to make it smart.
So I thought a D1 Mini piggy-backed to the remote would come in handy and do the job, and it did!
This is by no means an expert solution, and I’m sure there are better ways to write the code, but it works well. He’s hidden the remote in a cupboard anyway, and controls it via the companion app and automations.
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "blablabla"
ota:
  password: "blablabla"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Somfy-Remote Fallback Hotspot"
    password: ""
captive_portal:
web_server:
  port: 80
switch:
  - platform: gpio
    pin: 5
    inverted: True
    icon: "mdi:awning"
    on_turn_on:
    - delay: 1000ms
    - switch.turn_off: awning_close
  - platform: gpio
    pin: 4
    inverted: True
    icon: "mdi:awning"
    on_turn_on:
    - delay: 1000ms
    - switch.turn_off: awning_open
  - platform: gpio
    pin: 14
    inverted: True
    icon: "mdi:awning"
    on_turn_on:
    - delay: 1000ms
    - switch.turn_off: awning_stop
cover:
#    lambda: |-
#      if (id(top_end_stop).state) {
#        return COVER_OPEN;
#      } else {
#        return COVER_CLOSED;
    open_action:
      - switch.turn_on: awning_open
    close_action:
      - switch.turn_on: awning_close
    stop_action:
      - switch.turn_on: awning_stop
    optimistic: true
Awesome thank you!!!
Can you give pinouts, paint on the picture?
I can’t remember.
You really just need to know which one is the ground wire (marked) and then you can short the other 3 wires one at a time to the ground wire to figure out which is open, stop, close.
Neat, Ive been using this which has been working great for multiple Somfy RTS shuitters
rstrouse/ESPSomfy-RTS: A controller for Somfy RTS shades and blinds (github.com)
That’s awesome, thanks
Hi Simon, it’s interesting what you’ve done!
Maybe it’s better suited for the Share your Projects! category instead of configuration…
