Hi Guys,
can i control my Somfy Shutters directly with HomeAssistant?
I have an NanoCul and SignalDuino which i connected to the Pi.
I hope someone can help me.
Hi Guys,
Hello Der-Eine!
I intend to do the same as you describe.
Have found a solution?
Cheers,
Markus
I have no direct solution but you could use FHEM as middleware. I’m using Home Assistant and communicate over MQTT with FHEM. FHEM can easily use Signalduino for controlling Somfy shutters. I know it’s not the best solution but possible.
Bye
Hey, i use the same way. Install an Raspi and there is FHEM and HomeAssistant Supervised version.
From FHEM to HomeAssistant with MQTT. Runs smooth
FYI, there’s project at GitHub - markuzzi/somfy_cul_integration: Home Assistant integration framework to connect a CUL wireless transceiver to control SOMFY covers.
Not tested on my own, but sounds promising.
EDIT: tested now with a miniCUL USB stick running a-culfw firmware. Works fine here.
