Hello all,
Would be very thankfull if you could help in getting the Somfy remote ESP HA updated/working.
Thank you in advanced!
I am strugling with integrating Somfy RTS through ESPhome.
Trying to get 4 Somfy RTS shutters with Somfy remotes integrated in HA with a Wemos D1 Mini and a RF 433.42mhz Transmitter.
Hardware Wemos D1 mini
433mhz receiver transmitter (replaced the crystal with a 433.42 crystal)
Transmitter connected to D6
Receiver connected to D5 (to later read existing remotes)
Have also tried:
Issues with SPIFF and Ticker
and:
Tried to integrate one on one using: GitHub - dmslabsbr/esphome-somfy: Esphome configuration for Somfy Blind
Followed all the steps copied the needed files in the ESPhome directory.
Explanations of all three are straight forward and look very easy.
All three are from 2020 - 2021, maybe outdated due to software updates?
With Dmslabsbr GitHub - dmslabsbr/esphome-somfy: Esphome configuration for Somfy Blind i get the following:
First error i get in ESPhome befor installing/compiling:
arduino_version: [email protected] gives:
component not found arduimo version.
Compiling the code in ESPhome giving:
Error on Ticker:
- src/RFsomfy.h:4:10: fatal error: Ticker.h: No such file or directory
Warning regarding SPIFF:
- src/SomfyRts.cpp:190:3: warning: ‘SPIFFS’ is deprecated: SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
190 | SPIFFS.begin();
(See full log below…)
My Yaml:
esphome:
includes:
- RFsomfy.h
- SomfyRts.h
- SomfyRts.cpp
esp8266:
board: d1_mini
#arduino_version: [email protected]
#Gives an error in ESPhome: component not found arduimo version.
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "xxxxxxxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Somfy Fallback Hotspot"
password: "xxxxxxx"
captive_portal:
cover:
- platform: custom
lambda: |-
std::vector<Cover *> covers;
auto rfSomfy0 = new RFsomfy(0);
rfSomfy0->set_code(50);
App.register_component(rfSomfy0);
auto rfSomfy1 = new RFsomfy(1);
rfSomfy1->set_code(100); // Set initial rolling code. After it works, remove this line.
App.register_component(rfSomfy1);
auto rfSomfy2 = new RFsomfy(2);
App.register_component(rfSomfy2);
covers.push_back(rfSomfy0);
covers.push_back(rfSomfy1);
covers.push_back(rfSomfy2);
return {covers};
covers:
- name: "Blind 2"
device_class: shade
- name: "Veneziana casal"
device_class: shutter
- name: "Veneziana roxo"
text_sensor:
- platform: version
- platform: custom
lambda: |-
auto rfSomfyInfo = new RFsomfyInfo();
App.register_component(rfSomfyInfo);
return {rfSomfyInfo};
text_sensors:
binary_sensor:
- platform: status
The esphome logger returns:
INFO Reading configuration /config/esphome/somfy.yaml…
INFO Generating C++ source…
INFO Core config or version changed, cleaning build files…
INFO Deleting /data/somfy/.pioenvs
INFO Deleting /data/somfy/.piolibdeps
INFO Compiling app…
Processing somfy (board: d1_mini; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
LDF: Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
Dependency Graph
|-- 1.2.3
|-- 2.1.0
| |-- 1.2.3
| |-- 1.0
| |-- 1.0
|-- 1.1.1
|-- 1.0
|-- 1.2
Compiling /data/somfy/.pioenvs/somfy/src/SomfyRts.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/api_connection.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/api_frame_helper.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/api_pb2.cpp.o
src/SomfyRts.cpp: In member function ‘uint16_t SomfyRts::_readRemoteRollingCode()’:
In file included from src/SomfyRts.cpp:2:
/data/cache/platformio/packages/framework-arduinoespressif8266/cores/esp8266/FS.h:275:15: note: declared here
275 | extern fs::FS SPIFFS attribute((deprecated(“SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems.”)));
src/SomfyRts.cpp:191:7: warning: ‘SPIFFS’ is deprecated: SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
191 | if (SPIFFS.exists(_getConfigFilename())) {
src/SomfyRts.cpp:193:14: warning: ‘SPIFFS’ is deprecated: SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
193 | File f = SPIFFS.open(_getConfigFilename(), “r”);
src/SomfyRts.cpp:205:3: warning: ‘SPIFFS’ is deprecated: SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
205 | SPIFFS.end();
src/SomfyRts.cpp: In member function ‘void SomfyRts::_writeRemoteRollingCode(uint16_t)’:
src/SomfyRts.cpp:211:3: warning: ‘SPIFFS’ is deprecated: SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
211 | SPIFFS.begin();
src/SomfyRts.cpp:213:12: warning: ‘SPIFFS’ is deprecated: SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
213 | File f = SPIFFS.open(_getConfigFilename(), “w”);
src/SomfyRts.cpp:223:3: warning: ‘SPIFFS’ is deprecated: SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
223 | SPIFFS.end();
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/api_pb2_service.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/api_server.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/list_entities.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/proto.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/subscribe_state.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/user_services.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/binary_sensor/automation.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/binary_sensor/binary_sensor.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/binary_sensor/filter.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/cover/cover.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/custom/text_sensor/custom_text_sensor.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/esp8266/core.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/esp8266/gpio.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/esp8266/preferences.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/logger/logger.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/md5/md5.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/mdns/mdns_component.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/mdns/mdns_esp32_arduino.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/mdns/mdns_esp_idf.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/network/util.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/ota/ota_component.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/socket/socket.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/status/status_binary_sensor.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/text_sensor/filter.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/text_sensor/text_sensor.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/version/version_text_sensor.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/wifi/wifi_component.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/application.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/color.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/component.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/component_iterator.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/controller.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/entity_base.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/helpers.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/log.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/scheduler.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/util.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/main.cpp.o
In file included from src/main.cpp:33:
- Looking for Ticker.h dependency? Check our library registry!
- CLI > platformio lib search “header:Ticker.h”
- Web > PlatformIO Registry
4 | #include "Ticker.h"
compilation terminated.
*** [/data/somfy/.pioenvs/somfy/src/main.cpp.o] Error 1
========================= [FAILED] Took 111.40 seconds =========================
