Somfy RTS powersockets and Thermis IO Wirefree (thermostat)
I’m new to HA. In bought a Raspberry Pi 3 and a RFXCom RFXtrx433XL. I installed the latest version of Hassio and managed to add most of the devices i want to connect (Nest Smoke/CO detectors, Honeywell TCC, Sonos, Chromecast, TV, IP-cam, all of my Somfy sun blinds and shutters, etc.).
When i added the (Somfy) Tahoma component in my configuration all of my (Somfy IO) blinds, (Somfy IO) shutters and (somfy io) light/sun sensors where detected. What i don’t see is the temperature sensor (Somfy Thermis IO wirefree) and my Somfy RTS (433MHZ) power sockets. I would really like to add thes.
I found this URL but i really don’t understand what to do to add the RTS power sockets an the IO temperature sensor.
Can someone help this newby?
Thank you
Hi Freggel,
there is a pull request under way: https://github.com/home-assistant/home-assistant/pull/30053
:slightly_smiling_face:
