Somfy RTS, Wemos D1 mini, covers, shutter, ESPhome, github.com/dmslabsbr/esphome-somfy
Hello all,
Tried this topic at the ESP home section, unfortunately no response, maybe this is a better place for my question.
Thank you in advanced for your help.
I am strugling with integrating Somfy RTS through ESPhome.
Trying to get 4 Somfy RTS shutters with Somfy remotes integrated in HA with a Wemos D1 Mini and a RF 433.42mhz Transmitter.
Hardware Wemos D1 mini
433mhz receiver transmitter (replaced the crystal with a 433.42 crystal)
RF
Transmitter connected to D6
Receiver connected to D5 (to later read existing remotes)
Have also tried:
die-welt.net – 6 Jun 21
Controlling Somfy roller shutters using an ESP32 and ESPHome
Our house has solar powered, remote controllable roller shutters on the roof windows, built by the German company named HEIM & HAUS. However, when you look closely at the remote control or the shutter
Issues with SPIFF and Ticker
and:
GitHub
GitHub - evgeni/esphome-configs
Contribute to evgeni/esphome-configs development by creating an account on GitHub.
Tried to integrate one on one using: GitHub - dmslabsbr/esphome-somfy: Esphome configuration for Somfy Blind
Followed all the steps copied the needed files in the ESPhome directory.
Explanations of all three are straight forward and look very easy.
All three are from 2020 - 2021, maybe outdated due to software updates?
With Dmslabsbr GitHub - dmslabsbr/esphome-somfy: Esphome configuration for Somfy Blind i get the following:
First error i get in ESPhome befor installing/compiling:
arduino_version: [email protected] gives:
component not found arduimo version.
Compiling the code in ESPhome giving:
Error on Ticker:
  • src/RFsomfy.h:4:10: fatal error: Ticker.h: No such file or directory
Warning regarding SPIFF:
  • src/SomfyRts.cpp:190:3: warning: ‘SPIFFS’ is deprecated: SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
    190 | SPIFFS.begin();
    (See full log below…)
My Yaml:
esphome:
  includes:
    - RFsomfy.h
    - SomfyRts.h
    - SomfyRts.cpp
esp8266:
  board: d1_mini
#arduino_version: [email protected]
#Gives an error in ESPhome: component not found arduimo version.
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "xxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Somfy Fallback Hotspot"
    password: "xxxxxxx"
captive_portal:
cover:
- platform: custom
  lambda: |-
    std::vector<Cover *> covers;
    auto rfSomfy0 = new RFsomfy(0);
    rfSomfy0->set_code(50);
    App.register_component(rfSomfy0);
    auto rfSomfy1 = new RFsomfy(1);
    rfSomfy1->set_code(100);  // Set initial rolling code. After it works, remove this line.
    App.register_component(rfSomfy1);
    auto rfSomfy2 = new RFsomfy(2);
    App.register_component(rfSomfy2);
    covers.push_back(rfSomfy0);
    covers.push_back(rfSomfy1);
    covers.push_back(rfSomfy2);
    return {covers};
  covers:
    - name: "Blind 2"
      device_class: shade
    - name: "Veneziana casal"
      device_class: shutter
    - name: "Veneziana roxo"
text_sensor:
  - platform: version
  - platform: custom
    lambda: |-
      auto rfSomfyInfo = new RFsomfyInfo();
      App.register_component(rfSomfyInfo);
      return {rfSomfyInfo};
    text_sensors:
binary_sensor:
  - platform: status
The esphome logger returns:
INFO Reading configuration /config/esphome/somfy.yaml…
INFO Generating C++ source…
INFO Core config or version changed, cleaning build files…
INFO Deleting /data/somfy/.pioenvs
INFO Deleting /data/somfy/.piolibdeps
INFO Compiling app…
Processing somfy (board: d1_mini; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
LDF: Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
Dependency Graph
|-- 1.2.3
|-- 2.1.0
| |-- 1.2.3
| |-- 1.0
| |-- 1.0
|-- 1.1.1
|-- 1.0
|-- 1.2
Compiling /data/somfy/.pioenvs/somfy/src/SomfyRts.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/api_connection.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/api_frame_helper.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/api_pb2.cpp.o
src/SomfyRts.cpp: In member function ‘uint16_t SomfyRts::_readRemoteRollingCode()’:
In file included from src/SomfyRts.cpp:2:
/data/cache/platformio/packages/framework-arduinoespressif8266/cores/esp8266/FS.h:275:15: note: declared here
275 | extern fs::FS SPIFFS attribute((deprecated(“SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems.”)));
src/SomfyRts.cpp:191:7: warning: ‘SPIFFS’ is deprecated: SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
191 | if (SPIFFS.exists(_getConfigFilename())) {
src/SomfyRts.cpp:193:14: warning: ‘SPIFFS’ is deprecated: SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
193 | File f = SPIFFS.open(_getConfigFilename(), “r”);
src/SomfyRts.cpp:205:3: warning: ‘SPIFFS’ is deprecated: SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
205 | SPIFFS.end();
src/SomfyRts.cpp: In member function ‘void SomfyRts::_writeRemoteRollingCode(uint16_t)’:
src/SomfyRts.cpp:211:3: warning: ‘SPIFFS’ is deprecated: SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
211 | SPIFFS.begin();
src/SomfyRts.cpp:213:12: warning: ‘SPIFFS’ is deprecated: SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
213 | File f = SPIFFS.open(_getConfigFilename(), “w”);
src/SomfyRts.cpp:223:3: warning: ‘SPIFFS’ is deprecated: SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
223 | SPIFFS.end();
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/api_pb2_service.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/api_server.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/list_entities.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/proto.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/subscribe_state.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/api/user_services.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/binary_sensor/automation.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/binary_sensor/binary_sensor.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/binary_sensor/filter.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/cover/cover.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/custom/text_sensor/custom_text_sensor.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/esp8266/core.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/esp8266/gpio.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/esp8266/preferences.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/logger/logger.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/md5/md5.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/mdns/mdns_component.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/mdns/mdns_esp32_arduino.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/mdns/mdns_esp_idf.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/network/util.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/ota/ota_component.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/socket/socket.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/status/status_binary_sensor.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/text_sensor/filter.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/text_sensor/text_sensor.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/version/version_text_sensor.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/wifi/wifi_component.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/application.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/color.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/component.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/component_iterator.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/controller.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/entity_base.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/helpers.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/log.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/scheduler.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/esphome/core/util.cpp.o
Compiling /data/somfy/.pioenvs/somfy/src/main.cpp.o
In file included from src/main.cpp:33:
  • Looking for Ticker.h dependency? Check our library registry!
  • CLI > platformio lib search “header:Ticker.h”
  • Web > PlatformIO Registry
4 | #include "Ticker.h"
compilation terminated.
*** [/data/somfy/.pioenvs/somfy/src/main.cpp.o] Error 1
========================= [FAILED] Took 111.40 seconds =========================
Anybody facing the same issues, or have a “working” solution for Somfy RTS?
Thank you
Did you get this working? Facing the same problem at the moment…
Hi thommio,
Did not get this working. Have tried all the examples and codes that i have found, keep strugling with the missing libraries and not being able to include the libraries.
Looked like a simple integration using ESPhome.
Maybe somebody has found a solution to get this working.
I got it working, let me know if you still need help.
Hi Prbtt,
Fantastic that you got it working, i have been struggling for a long time and gave up…
Would be very keen finding out how you got it working so i can also get it working
Thank you in advanced for your help!
Hi there is a working solution but quite more expensive compared to ESP*
GCE RFPLAYER
GCE sells the RFPLAYER ( I own one and it is linked with 7 SOMFY RTS roller shutters ).
the RFPLAYER can handle 433 & 868 Mhz so it can work with many other protocols
the integration is still in development phase but so far RTS works. ( available via HACS )
Github project
Hope this helps.
I also just got it working with the cheap transmitters!
EDIT:
Made my own short guide and repostry on Github;
[original post]
Follow this guide:
https://www.die-welt.net/2021/06/controlling-somfy-roller-shutters-using-an-esp32-and-esphome/
It’s important that you use an ESP32 instead of esp8266/Wemos D1 mini.
You can use the cheap chinese transmitters instead of de CC1101
I followed this guide:
You’ll need an esp32+C1101 chip.
There’s plenty available on AliExpress afaik
I also developed a board that is home assistant ready to go. I’ll make a thread on that and share here. It was a lil bit more expensive since I only printed 5 of them… Hopefully I can actually turn it into a product that is useful for people! It has 16 progamable channels for blinds.
Here it is:
Hi Thommio, thank you for sharing your code.
I am still struggling and getting compilling errors.
Used your Github instructions and Yaml code one on one on a ESP-Wroom-32
esphome:
  platform: ESP32
  board: nodemcu-32s
  libraries:
    - EEPROM
    - SPI
    - [email protected]
    - [email protected]
  includes:
    - somfy_secrets.h
    - somfy_cover.h
wifi:
  ap:
    ssid: "Somfy-Nodemcu Fallback Hotspot"
captive_portal:
# Enable logging
logger:
api:
ota:
  password: "xxxxxxxxxxxxxxxxxxxxxxxx"
web_server:
  port: 80
  - platform: uptime
  - platform: wifi_signal
    name: "WiFi Signal Sensor"
cover:
  - platform: custom
    lambda: |-
      auto somfy_remote = new SomfyESPRemote();
      somfy_remote->add_cover("somfy", "woonkamer", SOMFY_REMOTE_WOONKAMER);
      somfy_remote->add_cover("somfy", "slaapkamer", SOMFY_REMOTE_SLAAPKAMER);
      App.register_component(somfy_remote);
      return somfy_remote->covers;
    covers:
      - id: "somfy"
      - id: "somfy2"
switch:
    turn_on_action:
      - lambda: |-
          ((SomfyESPCover*)id(somfy))->program();
    turn_on_action:
      - lambda: |-
          ((SomfyESPCover*)id(somfy))->stop();
    turn_on_action:
      - lambda: |-
          ((SomfyESPCover*)id(somfy2))->program();
    turn_on_action:
      - lambda: |-
          ((SomfyESPCover*)id(somfy2))->stop();
When compiling i get a similair error as i had with previous trials:
INFO Reading configuration /config/esphome/somfy-nodemcu.yaml…
INFO Compiling app…
Processing somfy-nodemcu (board: nodemcu-32s; framework: arduino; platform: platformio/espressif32 @ 5.2.0)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
  • toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
    Dependency Graph
    |-- AsyncTCP-esphome @ 1.2.2
    |-- EEPROM @ 2.0.0
    |-- SPI @ 2.0.0
    |-- SmartRC-CC1101-Driver-Lib @ 2.5.6
    |-- Somfy_Remote_Lib @ 0.4.1
    |-- WiFi @ 2.0.0
    |-- FS @ 2.0.0
    |-- Update @ 2.0.0
    |-- ESPAsyncWebServer-esphome @ 2.1.0
    |-- DNSServer @ 2.0.0
    |-- ESPmDNS @ 2.0.0
    |-- ArduinoJson @ 6.18.5
    Compiling /data/somfy-nodemcu/.pioenvs/somfy-nodemcu/src/SomfyRts.cpp.o
    src/SomfyRts.cpp:191:3: error: ‘SPIFFS’ was not declared in this scope
    SPIFFS.begin();
    src/SomfyRts.cpp:191:3: note: suggested alternative: ‘SPIFFS_gc’
    SPIFFS.begin();
    SPIFFS_gc
    src/SomfyRts.cpp:212:3: error: ‘SPIFFS’ was not declared in this scope
    SPIFFS.begin();
    src/SomfyRts.cpp:212:3: note: suggested alternative: ‘SPIFFS_gc’
    SPIFFS.begin();
    SPIFFS_gc
    *** [/data/somfy-nodemcu/.pioenvs/somfy-nodemcu/src/SomfyRts.cpp.o] Error 1
    ========================= [FAILED] Took 12.88 seconds =========================
Hi prbtt,
I followed that guide, see start of this post, getting compiling errors.
Also with using an ESP-Wroom-32
compiler complains about SPIFFS.
Any ideas?
You can use the on in my repo
Also, this one is a much better implementation with extra functionality
I came across this thread a couple of weeks ago and got snagged with the same compilation problems. I was able to tweak the code until it compiled and even worked, but it was not able to save it’s state to the ESP32 flash. I don’t think SPIFFS is a supported way to persist data in ESPHome.
There’s good documentation about the operation of RTS remotes, so I wrote my own ESPHome integration.
I see that there are now several good options in this thread, but anyone who wants to specifically use ESPHome and has a simple OOK transmitter like the one in the original post (instead of a CC1101) may find this implementation to be useful.
Thanks to everyone who chimed in here. I found a ton of useful information in these posts!
Hi jrseys,
Thank you for your post!
Have you got this working in Home Assistant? and can you share how your Yaml file looks?
(i have downloaded your files from Github, do not see a Yaml file calling the libraries.)
I am using the Esphome integration in Home Assistant, struggling for a while now trying to get this to work. Several solutions have been shared here but i did not get any to work mostly because of Spiffs compiling errors. Can not figur out how the other users have got it working.
Yes, ESPHome integrates perfectly with Home Assistant once you have it set up.
You shouldn’t need to download anything from the GitHub repository. Create a base ESPHome Yaml file and then add the external_components, remote_transmitter, rts, cover, sensor, and button config blocks from the README.md in my GitHub.
It’s still tricky to set up. I know I’m long winded, but I’d really recommend reading the entire README.md before trying to use this software with your window covers. Also, I’ve only tested this on my setup, so I can’t guarantee that it will work.
I tried “jrseys” version and can confirm that it works great, better than the one i posted before.
Here’s my working .yaml
esphome:
  friendly_name: rts control 2-5-2023
esp32:
  board: esp32dev
  framework:
    type: arduino
external_components:
  - source: github://jseyster/esphome-rts-control@master
    components: [ rts ]
# Enable logging
logger:
api:
  encryption:
    key: "C2C8c5Bbl4UgTAwj/l0egtI7/Fo1vSi18vk="
ota:
  password: "e17331ca85ad238d35431018e231c651"
wifi:
  ap:
    ssid: "Rts-Control-2-5-2023"
    password: "6r7NAvB5V5u2"
captive_portal:
# The transmitter must be configured for 100% duty cycle.
remote_transmitter:
  pin: GPIO4  # Use the number for the output pin connected to your radio.
  carrier_duty_percent: 100
rts:
  transmitter_id: rts_transmitter
  # Optional: you can configure how many times you want commands to
  # repeat to compensate for poor signal or interference. RTS devices
  # are designed to ignore any repeated commands that follow a
  # successful transmission.
  command_repetitions: 2  # The default.
cover:
  - platform: rts
    name: Living room shade
    device_class: shade
  - platform: rts
    name: Bedroom shade right
    device_class: shade
  - platform: rts
    name: Bedroom shade left (desk)
    device_class: shade
# Expose internal controller state for backup in case of data loss on
# the ESP microcontroller.
  - platform: rts
    rts_cover_id: shade_lv
    channel_id:
      name: Channel id of living room curtain controller
    rolling_code:
      name: Next rolling code value for living room curtain
  - platform: rts
    rts_cover_id: shade_brr
    channel_id:
      name: Channel id of living room shade controller
    rolling_code:
      name: Next rolling code value for living room shade
  - platform: rts
    rts_cover_id: shade_brl
    channel_id:
    rolling_code:
# Pairing buttons that can be removed after all "cover" devices are
# paired as desired.
button:
    name: Program living room shade
    on_press:
      - rts.program: shade_lv
    name: Program bedroom shade right
    on_press:
      - rts.program: shade_brr
    name: Program bedroom shade left
    on_press:
      - rts.program: shade_brl
