Is there already some integration with the Somfy set and go usb interface for home assistant?
Could you clarify what this device is? It looks like a tool for installers, connected via USB with a laptop.
Currently this is not supported in Home Assistant and since this is such a nice product, I don’t expect that anyone will work on building an integration. Your best option will be to change your Set & Go USB device for an supported Overkiz hub. (e.g. Somfy TaHoma v2 or Switch).
It’s correct it’s an tool special for installers to change parameters for different products.
But you can also control the devices locally and its cheaper than the Tahoma box.
So I was hoping
