I am not sure of the method to control Somfy shutters with Home Assistant through RFXCOM integration using a RFXCOM transceiver.
My configuration is:
- Synology NAS
- DSM 7.0.1-42218
- Virtual Machine Manager (VMM) 2.5.5-11487
- Home Assistant 2021.12.2
- RFXCOM RFXtrx integration (/integrations/rfxtrx/)
I customized my RFXtrx433XL interface using the RFXmngr application on my PC with ID “1 01 06” and unit code 1.
The RFY event code is 0c1a000001010601 (see screenshot below).
I can open or close my shutter with this RFXmngr application using the “Up” and “Down” commands.
Then I install the “RFXCOM RFXtrx” Home Assistant integration and customize as follow:
- Connection: serial
- Device: /dev/ttyUSB0 - RFXtrx433XL
- Event code: I made two trials (see below)
0c1a000001010601: I got a surprising error “Invalid event code”
071a000001010601: 3 entites were created
When I close or open the shutter, the event code mentioned in the “home-assistant.log” file does not correspond to one of the event codes mentioned above and the shutter does not respond to commands.
- open: 081a00000101060101
- close: 081a00000101060103
I don’t know what is wrong with my configuration. Is there a bug?
I admit being a little lost because the event code does not correspond to 0c1a00000101060101 or 0c1a00000101060103 and I think this is why it does not work.
I would be very grateful if someone could help me.
Following you will find extracts from the log file:
