Nmap says it’s closed, so maybe/probably not an error on HA side.
Any idea how that might come? I found nothing on Google regarding port and somfy, so out of ideas what to do. Can someone else do a port scan of this is normal?
Another restart has helped … the fifth one … This Somfy environment is just the worst you can imagine 2025. I will set Uptime Kuma to monitor port 8443 and restart the box if it is down.
Same problem here. It is almost exactly 1h after the last request made (automatically opening one shade in the morning). I’ll probably add a smart socket to reset it…
