I’d love to have a Sonarr sensor in Home Assistant to display upcoming episodes.
That’s a cool idea… I only just found Home Assistant… Trying it out tonight when I get home… Will start hopefully working on some component’s and will keep this one in mind!!
I love this idea.
Would also be cool if it could show the active downloads.
I wrote a sensor, and have a PR in for it, I implemented the endpoints that were a general return of data, vs the searching endpoints. Let me know what you think, I’m hoping this gets merged in!
Currently it can do:
- Number of series
- Number of upcoming episodes (with a configurable amount of days to look forward)
- Number of shows in queue (its called activity in the sonarr web ui)
- Number of active commands
- Number of shows in the Wanted section
- Available disk space
Hey it’s awesome this got in, thank you for your work on this!
I have one suggestion: I find that the best metric to know the health of my sonarr setup is, number of successful wanted items filled in the past 24/48/72 hours. I’m not sure if this information is available, and maybe I need to make this request to sonarr itself first, but, I’d be overjoyed if you’d consider it.
thanks, and great work
Glad you found the sensor useful! I was happy to get it merged in.
As for your request… I looked into it, and this might need some work on the Sonarr side of things. There is a history endpoint I can pull data from, and see what has downloaded, and that’s easy enough to sort by date and just look back as far as configured, but there doesn’t appear to be any indicator as to what triggered the download. So if a user triggers an automatic search for an episode not monitored, it can still find it, and download it and it would show up in this history component. That being said, if you would find it useful to see the number of episodes downloaded within X days/hours, that would be a pretty quick addition and I can work on that to get it in the next release.
Episodes succesfully downloaded in X time would be fantastic. That’s all I need to quickly know that things are not going disastrously wrong. thanks for this!
Hey,
is it possible to do the same for Radarr (sonarr for movies), it’s almost identical I think
Lidarr (sonarr for music) is still in development, but when it’s done it would also be appreciated
also if it would be possible to get the names of the episodes/movies that would be amazing, I see them listed as attributes.
Is there a way, we can see the downloaded shows in the past x days ?
im using sonarr on synology nas but i cant get the sensor working.
Nothing shows up in log. This should be right ?
- platform: sonarr api_key: xxxxxx host: 192.168.1.135 port: 8989 monitored_condition: - series
tried resetting api key without sucess… ip and port is 100% right
Bumping this. Any chance anyone found a solution to this?
Works fine on mine and never stoped working
- platform: sonarr api_key: XXXXXXXXXXXXXXXXX host: 192.168.86.38 port: 8989 monitored_conditions: - upcoming - wanted - queue days: 1
I was referring to the question above “Is there a way, we can see the downloaded shows in the past x days ?”
Has anyone found a solution to that?
I don’t know if this will help but I achieved something close to that with node-red and MQTT . Basically when sonarr or raddarr download something, Webhook POST’s json payload to my Node-Red server URL where Node-red then posts to my MQTT server, then Home Assistant MQTT sensor picks it up and then sends to tts then Chromecast Audio. and I get " Good morning , TV show Game of Thrones has just been downloaded ",
and in my MQTT sensor History it shows when and what sonarr/radarr downloaded.
Anyone know how to monitored conditions all is coming up is upcoming. I running HA 112. Have not got anything in my config as It’s looks like the old way. I have done it in the UI
![Screenshot_20200709-110513_Home Assistant|236x500]they are disabled - you need to go into the device and enable them
Thanks man Lol worked it out. Funny I using your theam add-on. One thing not work is the sonarr version I’m running… love to chat on discord Monday with you. Work mm most of your code Sab is giving me troubles
.I don’t see Sonarr Version as an option for the device
