Hi
i cant add Sonarr to my integration, i’m using Sonarr v3 on another Win 10 on my network, all the info i can find is about sonarr v2.
Thank you
Hi
Thank you
Hey, I’m not able to add it either (I get “failed to connect” even with all my details correctly entered) and I’m on Sonarr v3 too. Did you ever figure out a solution to this?
I’m also having the same issue and can’t figure it out. Sonarr logs say 200 OK to all the requests made to the API from home assistant but it still says failed to connect.
did anyone find a fix to this ?
is the url meant to be a special format ?
is the config of sonarr meant be done in a special way ? ssl? etc
why doesnt the documentation detail any of this ???
