Sonnar warnings in Home Assistant log file
I am using Sonarr, Radarr and MariaDB as containers on the same host. Home Assistant connects to all of them the same way. Only Sonarr produces WARNING messages in the log file for some reason.
Any idea why this could be happening?
2020-03-18 09:07:58 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_series is taking over 10 seconds
2020-03-18 09:07:58 WARNING (SyncWorker_38) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:08:08 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_queue is taking over 10 seconds
2020-03-18 09:08:08 WARNING (SyncWorker_11) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:08:18 WARNING (MainThread) [homeassistant.components.sensor] Updating sonarr sensor took longer than the scheduled update interval 0:00:30
2020-03-18 09:08:18 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_upcoming is taking over 10 seconds
2020-03-18 09:08:18 WARNING (SyncWorker_39) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:08:28 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_disk_space is taking over 10 seconds
2020-03-18 09:08:28 WARNING (SyncWorker_27) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:08:38 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_wanted is taking over 10 seconds
2020-03-18 09:08:38 WARNING (SyncWorker_9) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:08:59 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_upcoming is taking over 10 seconds
2020-03-18 09:08:59 WARNING (SyncWorker_21) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:09:09 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_disk_space is taking over 10 seconds
2020-03-18 09:09:09 WARNING (SyncWorker_31) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:09:19 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_series is taking over 10 seconds
2020-03-18 09:09:19 WARNING (SyncWorker_27) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:09:20 WARNING (MainThread) [homeassistant.components.sensor] Updating sonarr sensor took longer than the scheduled update interval 0:00:30
2020-03-18 09:09:29 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_queue is taking over 10 seconds
2020-03-18 09:09:29 WARNING (SyncWorker_33) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:09:39 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_wanted is taking over 10 seconds
2020-03-18 09:09:39 WARNING (SyncWorker_11) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:10:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_series is taking over 10 seconds
2020-03-18 09:10:00 WARNING (SyncWorker_13) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:10:14 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_upcoming is taking over 10 seconds
2020-03-18 09:10:14 WARNING (SyncWorker_5) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:10:21 WARNING (MainThread) [homeassistant.components.sensor] Updating sonarr sensor took longer than the scheduled update interval 0:00:30
2020-03-18 09:10:24 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_wanted is taking over 10 seconds
2020-03-18 09:10:24 WARNING (SyncWorker_2) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:10:34 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_disk_space is taking over 10 seconds
2020-03-18 09:10:34 WARNING (SyncWorker_35) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:11:02 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_disk_space is taking over 10 seconds
2020-03-18 09:11:02 WARNING (SyncWorker_1) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:11:12 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_upcoming is taking over 10 seconds
2020-03-18 09:11:12 WARNING (SyncWorker_2) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:11:22 WARNING (MainThread) [homeassistant.components.sensor] Updating sonarr sensor took longer than the scheduled update interval 0:00:30
2020-03-18 09:11:22 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_wanted is taking over 10 seconds
2020-03-18 09:11:22 WARNING (SyncWorker_34) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:11:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_series is taking over 10 seconds
2020-03-18 09:11:32 WARNING (SyncWorker_29) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:11:42 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_queue is taking over 10 seconds
2020-03-18 09:11:42 WARNING (SyncWorker_27) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:12:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_upcoming is taking over 10 seconds
2020-03-18 09:12:03 WARNING (SyncWorker_18) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:12:13 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_wanted is taking over 10 seconds
2020-03-18 09:12:13 WARNING (SyncWorker_28) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:12:23 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_queue is taking over 10 seconds
2020-03-18 09:12:23 WARNING (SyncWorker_25) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:12:24 WARNING (MainThread) [homeassistant.components.sensor] Updating sonarr sensor took longer than the scheduled update interval 0:00:30
2020-03-18 09:12:33 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_series is taking over 10 seconds
2020-03-18 09:12:33 WARNING (SyncWorker_4) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:12:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_disk_space is taking over 10 seconds
2020-03-18 09:12:43 WARNING (SyncWorker_37) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:13:05 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_disk_space is taking over 10 seconds
2020-03-18 09:13:05 WARNING (SyncWorker_19) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:13:15 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_queue is taking over 10 seconds
2020-03-18 09:13:15 WARNING (SyncWorker_31) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:13:25 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_series is taking over 10 seconds
2020-03-18 09:13:25 WARNING (SyncWorker_12) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:13:26 WARNING (MainThread) [homeassistant.components.sensor] Updating sonarr sensor took longer than the scheduled update interval 0:00:30
2020-03-18 09:13:35 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_wanted is taking over 10 seconds
2020-03-18 09:13:35 WARNING (SyncWorker_14) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:13:45 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_upcoming is taking over 10 seconds
2020-03-18 09:13:45 WARNING (SyncWorker_13) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:14:07 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_upcoming is taking over 10 seconds
2020-03-18 09:14:07 WARNING (SyncWorker_32) [homeassistant.components.sonarr.sensor] Host 192.168.1.23 is not available
2020-03-18 09:14:17 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.sonarr_wanted is taking over 10 seconds
