SonnenBatterie sensors and switches
Maybe not the best code around, but quick to use for SonnenBatterie owners. It is easy to read and thus to expand using the battery’s API information. In combination with nabu casa it’s perfect before your vacation!
Cheers,
Mischa
rest:
  • resource: http://[IP address]:80/api/v2/status
    method: GET
    headers:
    User-Agent: Home Assistant
    Content-Type: application/json
    Auth-Token: [TOKEN]
    scan_interval: 10
    • name: “Backup Buffer”
      value_template: ‘{{ value_json[“BackupBuffer”] }}’
      unit_of_measurement: “%”
      device_class: battery
    • name: “Operating Mode (1 = API, 2 = Auto, 10 = ToU)”
      value_template: ‘{{ value_json[“OperatingMode”] }}’
    • name: “Battery Charging”
      value_template: ‘{{ value_json[“BatteryCharging”] }}’
    • name: “Battery Discharging”
      value_template: ‘{{ value_json[“BatteryDischarging”] }}’
    • name: “User State of Charge”
      value_template: ‘{{ value_json[“USOC”] }}’
    • name: “System Status On Grid or Off Grid”
      value_template: ‘{{ value_json[“SystemStatus”] }}’
    • name: “AC Power, positive is discharging”
      value_template: ‘{{ value_json[“Pac_total_W”] }}’
      unit_of_measurement: “Watt”
      device_class: power
  • resource: http://[IP address]:80/api/v2/latestdata
    method: GET
    headers:
    Auth-Token: [TOKEN]
    scan_interval: 10
    • name: “Timestamp”
      value_template: >
      {% set timestamp = value_json[“Timestamp”] %}
      {{ as_timestamp(timestamp) | timestamp_local }}
      device_class: timestamp
rest_command:
set_operating_mode_manual:
url: “http://[IP address]:80/api/v2/configurations”
method: PUT
headers:
Auth-Token: [TOKEN]
payload: ‘{“EM_OperatingMode”: “1”}’
set_operating_mode_auto:
method: PUT
headers:
Auth-Token: [TOKEN]
payload: ‘{“EM_OperatingMode”: “2”}’
set_discharge_9500_watts:
url: “http://[IP address]:80/api/v2/setpoint/discharge/9500”
method: POST
headers:
Auth-Token: [TOKEN]
payload: “{}”
set_charge_9500_watts:
url: “http://[IP address]:80/api/v2/setpoint/charge/9500”
method: POST
headers:
Auth-Token: [TOKEN]
payload: “{}”
set_discharge_0_watts:
url: “http://[IP address]:80/api/v2/setpoint/discharge/0”
method: POST
headers:
Auth-Token: [TOKEN]
payload: “{}”
switch:
  • platform: template
    switches:
    friendly_name: “Set Operating Mode Manual”
    icon_template: mdi:cog
    value_template: “{{ is_state(‘sensor.operating_mode_1_api_2_auto_10_tou’, ‘1’) }}”
    turn_on:
    service: rest_command.set_operating_mode_manual
    turn_off:
    service: rest_command.set_operating_mode_auto
    friendly_name: “Set Operating Mode Auto”
    icon_template: mdi:autorenew
    value_template: “{{ is_state(‘sensor.operating_mode_1_api_2_auto_10_tou’, ‘2’) }}”
    turn_on:
    turn_off:
    discharge_9500:
    friendly_name: “Set Discharge to 9500 Watts”
    icon_template: mdi:battery-charging-100
    value_template: “{{ is_state(‘sensor.ac_power_positive_is_discharging’, ‘9500’) }}”
    turn_on:
    service: rest_command.set_discharge_9500_watts
    turn_off:
    service: rest_command.set_discharge_0_watts
    charge_9500:
    friendly_name: “Set Charge to 9500 Watts”
    value_template: “{{ is_state(‘sensor.ac_power_positive_is_discharging’, ‘-9500’) }}”
    turn_on:
    service: rest_command.set_charge_9500_watts
    turn_off:
    discharge_0:
    friendly_name: “Set Discharge to 0 Watts”
    value_template: “{{ is_state(‘sensor.ac_power_positive_is_discharging’, ‘0’) }}”
    turn_on:
    turn_off:
