kalpcc
(Kenneth Lawrence)
March 4, 2018, 10:33pm
1
Hi.
Currently i have wifi signal strength listed in HA (hassio).
In the same line i want the SSID name, to be listed as well.
value_template: “{{ (value_json.Wifi.SSID) }}” + value_template: “{{ (value_json.Wifi.RSSI) }}”
What is the notation for that?
I am thinking that it should look something like this: (but it is still wrong notation)
Here is my working config for RSSI:
- platform: mqtt
name: "WiFi kontor loft lys 10"
state_topic: "tele/kontorloft/STATE"
value_template: "{{ (value_json.Wifi.RSSI) }}"
unit_of_measurement: "%"
And this is how i what it to look like:
Regards,
Kenneth
I’m pretty sure what you want can be done with the custom-ui add on, but will probably still need to be two sensors to extract both pieces of into
kalpcc
(Kenneth Lawrence)
March 5, 2018, 12:44pm
3
jivesinger:
custom-ui add
Well. i did make another sensor for the AP info. And i grouped the info. It is a bit messy, but it works.
I still want the AP info in the same line, but i dont know the notation
Maybe, i will just leave it, as it is.
I still hope, that someone knows how to nest two json values in one value_template.
Here is the output from the Sonoff module:
15:34:41 MQT: tele/kontorloft/STATE = {"Time":"2018-03-05T15:34:41","Uptime":3,"Vcc":3.154,"POWER":"OFF","Wifi":{"AP":1,"SSId":"KL2_4GH","RSSI":82,"APMac":"40:A5:EF:22:E9:3B"}}
kalpcc
(Kenneth Lawrence)
March 5, 2018, 2:13pm
4
I found out that it is from the group, that i want to show the two entities:
sonoff_wifi_signal_strength:
name: Sonoff wifi signal strength
entities:
- {[sensor.ap_kontor_seng_lys_10],[ sensor.wifi_kontor_seng_lys_10]}
But the syntax is still wrong
