Hello
I’m trying to setup the zigbee2mqtt configuration using sonof 3.0 dongle plus. Every time when i start Z2M i get response about undefined error “Error while starting zigbee-herdsman”.
[09:14:50] INFO: Preparing to start...
[09:14:53] INFO: Socat not enabled
[09:15:01] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2023-04-05 09:15:36: Logging to console and directory: '/config/zigbee2mqtt/log/2023-04-05.09-15-36' filename: log.txt
Zigbee2MQTT:info 2023-04-05 09:15:37: Starting Zigbee2MQTT version 1.30.3 (commit #unknown)
Zigbee2MQTT:info 2023-04-05 09:15:37: Starting zigbee-herdsman (0.14.103)
Zigbee2MQTT:error 2023-04-05 09:15:53: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-04-05 09:15:53: Failed to start zigbee
Zigbee2MQTT:error 2023-04-05 09:15:53: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-04-05 09:15:53: Exiting...
Zigbee2MQTT:error 2023-04-05 09:15:53: undefined
So below you can find my configuration
Z2M:
Of course i have configured Mosquitto Broker. Additional information, I had configured also Conbee II and everythings worked very well, but i wanna switch to sonoff because i got information that this work better with more added devices.
Do you know what the problem could be? The only thing that makes me wonder is that i’m using Raspberry 3 which have just USB 2.0 but sonoff has USB 3.0 but i’m nut sure that this is the case.
